Hello To All
The ccs language has been a comfortable to work whit some devices however recently i can see that isn´t the best tool to manage and get serial Hex strings, in the past i don´t need to work whit serial port and many of my projects are under ccs, now when i try to build a program to connect my pic whit pc using realterm to receive on rx signal pin the string 02,05,FB,29 and everything is confuse i can send hex data properly whit putc and tx works fine but the strings management under ccs is very complicated, i read ccs examples for buffer treatment and do you need usage the kbhit sentence. reading about the same proccess whit other c compiler this task is more simple and you can control the reception buffer easy way. I´ts time to leave the ccs languaje and try to migrate to other compiler? any advice to change.
Thanks in advance for any reply about this issue.
