need your help in elevator program
mshh
Full Member level 6
Full Member level 6
usa
this is the elevator algorithm that i want to do. i did it using state machine but i have a problem with storing requests while the elevator is moving
1-the elevator is at ground floor as a default then somebody calls it from nth floor during it's travel to up somebody in n-2 and n-3 called it so the elevator should go up to (n-3) floor then to (n-2) floor then to nth floor.
2- there will be seven segment and arrows to display its state and floor number ( i will hold this step now)
3- during going up somebody called the elevator to go down , but the elevator will complete it's first orders then stop and go down.
the same time that happens when going up will happen when going down if somebody in between top floor and bottom pressed a button it should stop and take him
4-if two buttons pressed at the same time go to the first one the elevator way (up or down)
5- when there are no requests the elevator is waiting at the last called floor and its door is opened .
6-when it is moving the doors should be closed and make sure it isn't opened . when the elevator stopped at the called floor don't move if the door is opened
i think that's all for now. the problem here is that i don't know how to store requests during its moving
inputs and outputs for 5 floors
inputs:
the inside buttons are connected in parallel with the outside call button just one button for up and down so i show just the inside buttons
1- BUTTON_0 //push button for first floor inside the elevator
2-BUTTON_1
3-BUTTON_2
4-BUTTON_3
5-BUTTON_4 //push button for 5th floor
6- SENSOR_0 // proximity sensor in the first floor that will sense the elevator existence
7-SENSOR_1
8-SENSOR_2
9-SENSOR_3
10-SENSOR_4
outputs:
1-go up( for the motor control)
2- go down
3- fast (for the motor working with up or down) when it is far from requested floor
4-slow (for the motor working with up or down) when reached
5-seven segment display floor number
6 - up and down arrow
7- lock for the door
the algorithm and input and outputs ,every thing is here except the code
this is the basic requirements for the elevator then i will update it if needed.
Code dot - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
#include <mega16.h>
#include <delay.h>
#define BUTTON_0 PINC.0
#define BUTTON_1 PINC.1
#define BUTTON_2 PINC.2
#define BUTTON_3 PINC.3
#define BUTTON_4 PINC.4
#define SENSOR_0 PIND.0
#define SENSOR_1 PIND.1
#define SENSOR_2 PIND.2
#define SENSOR_3 PIND.3
#define SENSOR_4 PIND.4
#define MOVE_UP    PORTB.1
#define MOVE_DOWN PORTB.2
enum elevator_state {
PARKED_0,PARKED_1,PARKED_2 ,PARKED_3 , PARKED_4 ,
UP_TO_1   , UP_TO_2 , UP_TO_3   , UP_TO_4 ,DOWN_TO_3, DOWN_TO_2,
   DOWN_TO_1, DOWN_TO_0
enum motor_direction {
STOP      = 0,   // send 0 to portb to stop the elevator
unsigned char state = PARKED_0;
unsigned char motor=STOP;
void error(void)
motor = STOP;
for(;;) {
     PORTB.5 = 1;
void main(void)
PORTB=0x00;DDRB=0xFF;
PORTC=0x00;DDRC=0x00;
PORTD=0x00;DDRD=0x00;
for( ;; ) {
     switch( state ) {
      case PARKED_0:
         if (BUTTON_1 | BUTTON_2 | BUTTON_3 | BUTTON_4) {
           state = UP_TO_1;
          PORTB.1=1;
        else{
        PORTB=0;      //clear up
         break;
      case PARKED_1:
        if (BUTTON_2 | BUTTON_3 | BUTTON_4) {
          state = UP_TO_2;
          PORTB.1=1; // motor up
        else if (BUTTON_0) {
          state = DOWN_TO_0;
           PORTB.2=1;     // /down
        else{
                   PORTB=0;      //stop the motor
          break;
      case PARKED_2:
        if (BUTTON_3 | BUTTON_4) {
          state = UP_TO_3;
           PORTB.1=1;
        else if (BUTTON_0 | BUTTON_1) {
          state = DOWN_TO_1;
        PORTB.2=1;     // /down
          else{
          break;
      case PARKED_3:
        if (BUTTON_4) {
          state = UP_TO_4;
        PORTB.1=1;
        else if (BUTTON_0 | BUTTON_1 | BUTTON_2 ) {
          state = DOWN_TO_2;
           PORTB.2=1;     // /down
          break;
      case PARKED_4:
        if (BUTTON_0 | BUTTON_1 | BUTTON_2 | BUTTON_3) {
        PORTB.2=1;      // down
          break;
        case UP_TO_1:
           state = UP_TO_2;
             PORTB.1=1;
          if (SENSOR_1) {
          delay_us(10);
            state = PARKED_1;
        PORTB.1=0;
          else {
             PORTB.1=1;
          break;
        case UP_TO_2:
           state = UP_TO_3;
           PORTB.1=1;
           if (SENSOR_2) {
            state = PARKED_2;
          PORTB.1=0;
          else {
            motor = MOVE_UP;
          break;
        case UP_TO_3:
        if (BUTTON_4) {
           state = UP_TO_4;
           PORTB.1=1;
        if (SENSOR_3) {
            state = PARKED_3;
       PORTB.1=0;      //clear up
          else {
       PORTB.1=1;
          break;
        case UP_TO_4:
          if (SENSOR_4) {
            state = PARKED_4;
PORTB.1=0;
          else {
            motor = MOVE_UP;
          break;
     case DOWN_TO_0:
          if (SENSOR_0) {
            state = PARKED_0;
             PORTB.2=0;      //stop the motor
          else {
             PORTB.2=1;     // /down
      case DOWN_TO_1:
        if (BUTTON_0) {
           state = DOWN_TO_0;
           PORTB.2=1;     // /down
        else if (SENSOR_1) {
            state = PARKED_1;
          else {
             PORTB.2=1;     // /down
     case DOWN_TO_2:
           if (BUTTON_1 | BUTTON_0) {
           state = DOWN_TO_1;
           PORTB.2=1;     // /down
          if (SENSOR_2) {
            state = PARKED_2;
          else {
             PORTB.2=1;     // /down
             PORTB.1=0;     // clear up
     case DOWN_TO_3:
           if (BUTTON_2 | BUTTON_1 | BUTTON_0) {
           state = DOWN_TO_2;
             PORTB.2=1;     // /down
          else if (SENSOR_3) {
            state = PARKED_3;
          else {
             PORTB.2=1;     // /down
            break;
      default:
        error();
Make an array in your program LILO(Last In Last Out). When ever a button is pressed the number is stored into your array. The elevator will ultimately go to the highest number. Using array technique you can solve the problem. If you need more help let us know.
yes please i don't know how to use array technique inside my code so if you write it i will be grateful and i will complete the code based on your help
5 step elevator program and circuit pic16f877 - picbasic
'*  Name    : UNTITLED.BAS                                      *
'*  Author  : [select VIEW...EDITOR OPTIONS]                    *
'*  Notice  : Copyright (c) 2008 [select VIEW...EDITOR OPTIONS] *
'*          : All Rights Reserved                               *
'*  Date    : 2008/01/02                                        *
'*  Version : 1.0    b                                           *
'*  Notes   : mehdi rajabi 09125354921  [url]www.omidravanro.com[/url]                                                  *
trisa=%000000      ; port a khoruji                   1 v
trisb=%11000011      ; port b vorudi$khuruji            0 kh
trisc=%11111111      ; port c vorudi
trisd=%00000000     ;port d khoruji
trise=%111          ; port e vorudi
key0 var portc.4
key1 var portc.3
key2 var portc.2
key3 var portc.1
key4 var portc.0
symbol SENs0=portb.1
symbol SENs4=portb.0
symbol usens=portb.6
symbol dsens=portb.7
symbol upled = portb.2
symbol hiled = portb.3
symbol loled = portb.4
symbol DOWNled = portb.5
b0 var byte
b1 var byte
test:
portb=%11000011
portd=%00000000
pause 100
main:          ;agar asansor dar paintarin tabaqe bud shenasai naravad.
if sens0=0 then
goto chek
else
goto shenasai
endif
shenasai:      ;asansor az har ja shasti begirad jahat shenasai be paiin beravad.
if key0=1 or key1=1 or key2=1 or key3=1 or key4=1 and sens0=1 then
downled=1
goto  jahatdn
else
goto shenasai
endif
jahatdn:
if sens0=0  then
pause 10
downled=0
pause 10
goto chek
else
downled=1
goto jahatdn
endif
chek:
low portd.7
pause 10
high portd.7
pause 10
if key0=1 or key1=1 or key2=1 or key3=1 or key4=1  then park
goto chek
park:
if key0=1 and sens0=1 then
high key0
pause 10
endif
if key1=1 then
high key1
pause 10
endif
if key2=1 then
high  key2
pause 10
endif
if key3=1 then
high  key3
pause 10
endif
if key4=1 and sens4=1 then
high key4
pause 10
endif
if b1=$3f and key1=1 or key2=1 or key3=1 or key4=1then runup
pause 10
if b1=$06 and key2=1 or key3=1 or key4=1 then runup
pause 10
if b1=$5b and key3=1 or key4=1 then runup
pause 10
if b1=$4f and key4=1 then runup
pause 10
if b1=$66 and key0=1 or key1=1 or key2=1 or key3=1 then rundown
pause 10
if b1=$4f and key0=1 or key1=1 or key2=1 then rundown
pause 10
if b1=$5b and key0=1 or key1=1 then rundown
pause 10
if b1=$06 and key0=1 then rundown
pause 10
     ; b0,[$3f,$06,$5b,$4f,$66,$6d,$7d,$07,$7f,$6f],b1  10 tabaqe (0 to 9)
stop1:
lookup b0,[$3f,$06,$5b,$4f,$66],b1         ; tarif 5 tabaqe
portd=b1
if usens=1  then
b0=b0+1
write 1,b1
pause 10
endif
if dsens=1   then
b0=b0-1
write 1,b1
pause 10
endif
if b1=$3f or sens0=0 and key0=1 then     ;0
hiled =0
downled=0
key0 =0
pause 10
endif
if b1=$06 and key1=1 then       ;1
 upled =0
 downled =0
 key1 =0
pause 10
endif
if b1=$5b and key2=1 then      ;2
low upled
low downled
low key2
pause 10
endif
if b1=$4f and key3=1 then      ;3
upled=0
downled=0
low key3
pause 10
endif
if b1=$66 or sens4=0 and key4=1 then      ;4
upled=0
downled=0
low key4
pause 10
endif
pause 50
;goto stop1
goto park
runup:
downled=0
pause 50
upled=1
pause 20
goto stop1
rundown:
upled=0
pause 50
downled=1
pause 20
goto stop1
;goto chek
         end
