I have tried a variety of circuits available here and from google of wiggler to program the flash of my mcu i.e ATmels arm aduc7022 but in vain ,
so if anybody could ps send me the correct schematic and the software to program aduc7022 . i will consider it as a help .
and will give 50 points as token for keeping up the spirits of what this forum is all about i.e learning through sharing.
I bought the MiniKit for ADuC702x from Analog Devices. The kit uses the serial port downloader (ARMWSD), which is free from Analog Devices' web site. If you are happy with this solution, I can send you the schematic of the kit, so you can wire your chip up to use their downloader.
Hi!
I have made this circuit and i have been using it for the past 6 months without any problems, but the trick is that for communiction from the pc to the wiggler circuit i use a ribbon cable with DB25 attached to both the ends. You probably won't believe that the length of the cable is more than 1 meter. Not only i but all my colleagues use it.
