Need VCXO PLL Design for T1/E1 (ref. des, methods, etc.)
VicL
Member level 1
Member level 1
Old Great Europe
mt9076 software drivers
TO RESPECT THE G703 REQUIREMENTS YOU CAN USE A SIMPLE 2048 +- 50 PPM OSCILLATOR THAT NOT REQUIRE A HARD SCHEMATIC
RE
I have incomming data link E1.
I`m need to extract clock and form some framing signal
from data stream
if you need only to extract clock and timing you can use or LIU(line interface unit) and Framer (you can also implement it in a FPGA) or you can use a single chip (liu + framer ) that perform all operations.
the only one that you need is a oscillator +- 50 ppm to meet the E1 requirements.
look to dallas-maxim or infineon or zarlink to find the appropiate device or a data sheet to now ohw to.
bye
As talpina wrote, you can use
Dallas DS2155 LIU + PLL + Framer + 2*HDLC :
h**p://w*w.maxim-ic.com/quick_view2.cfm?qv_pk=2859&ln=
Infineon FALC56 (PEB2256) LIU + PLL + Framer + 3*HDLC :
h**p://w*w.infineon.com/cgi/ecrm.dll/ecrm/scripts/prod_ov.jsp?oid=13588&cat_oid=-10080
Pmc Sierra E1XC (PM6341) LIU + PLL + Framer :
h**p://w*w.pmc-sierra.com/products/details/pm6341/index.html
Zarlink MT9076B LIU + PLL + Framer + 3*HDLC :
h**p://products.zarlink.com/product_profiles/MT9076B.htm
All these chips are working with a standard 50ppm oscillator. In some case you can download software drivers from the manufacturer's site
We are use MT9076 + MT9042 (PLL)
MT9076 have a 2.048/1.544 extracted frequency,
and we use MT9042 for 16.384 and some framing pulses
generation.
But custom PLL more coct effective.
Hi
Keep locking at :
h**p://w*w.actel.com/appnotes/s04_18.pdf
Remember to take care about jitter if you want to devellop your own PLL
papyaki said:
Hi
Keep locking at :
Thanks!
I have this documents.
But VCXO PLL more cheap and effective, IMHO
if you want to synchronize your system clock to different reference clocks take a PLD, divide the system clock (generated by a VCXO) and reference clock to e.g. 8kHz (=>frame sync) and combine them with XOR logic. The result is a measure for the clock difference. You can feed it to the VCXO adjust via an integrator build with resistor/capacitor.
