m_eh_62
Member level 2
wavelet somoth filter matlab code
I used Data base in Physionet.org
and i convert the records to Matlab reabale format(ecg.mat)
then i eliminate the baseline drift and finaly
apply wavelet transform to this signal
and my purpose is feature extraction of this signal:
more accurate
I want detect QRS,P,T segment of this signal with
the following algorithm in this article(ECG FEATURE EXTRACTION
USING DAUBECHIES WAVELETS.pdf)
I've some problem in this project:
1)in baseline drift elimination I use the smooth function in Matlab and it's syntax is:
Z=smooth(Y,span)
i've read an article about baseline drift Elimination it said that :
'' the appropriate smoothing factor is determined by dividing one waveform
period (in seconds) by the Channel's sample interval "
but i dont know neither one.
I chose the Span equal 150 and the baseline drift eliminate apparently.
what is the exact Span for my signal?Can everybody calculate it exactly?
2)I want to apply the following algorithm in this article
but i dont know for example in R wave detection How should
I keep detail between d3-d5??
or in Q & S detection how should I keep detail greater than db5 in
wavelet either in matlab?
Shall I design a filter for it?
if need be how can design it?
more accurate
Z=smooth(Y,span)
