need solution on voltage level translation
vishu489
hi friends I'm trying to interface glucometers with atmega16 on uart. but the problem is that one of my glucometer gives LVTTL interface logic(0 to 3.3v) and another one gives rs232 signal (-12V t0 +12v)
and one more glucometer gives TTL o/p (0 to 5v). but the problem is that my controller is capable to read signal ranging from 0 to 3.3v. so how can i make my atmega16 uart compatible with all 3 meters.
basically i need voltage conversion solution so that what will be the voltage coming from glucometer , it should be converted into voltage compatible with atmega16 uart. thank you in advance:lol::lol:
thanks for your reply. but that solution i already know . i don't want to change hardware every time i change my glucometer. i want one global solution such that i can maintain compatibility with different glucometer.
i wanted to do something as below
glucometer(o/p: LVTTL, TTL ,RS232) -------> VOLTAGE TRANSLATION---------> ATMEGA16 UART
that voltage translation must have to sense this logic and convert it into compatible signal of atmega16 uart(LVTTL)
