Need schematic for current source for 30uAmp
BABESH
Full Member level 2
Need 30uA current source
Hi
I need schematic for current source for 30uAmp
My load is grounded resistive type sensor as load.
--babesh.
Re: Need 30uA current source
See schematic of HP3478A. From Hewlet Packard (todays Agilent). There's best drawn schematic of current source with ranges of 100nA to 1mA (not sure for upper range)
Use oamps AD706 and for current source I will fill in today. (I don't remember exactly). Or see schematic Agilent 34401A. Watchout the lownoise, low input current oamp (unipolar input amplifier with low noise like TL051, AD706, ... ) or it will not work properly.
Good luck
    BABESH
Thanks Ali Bhai,
I got it, i picked up the circuit,
I don't need it much rugged one, first i will try to implement using any opamp
Thanks
Babesh.
Ok, I found my schematic. I used AD706 for bias amps and TL051 for current source. In current source I have transistor 2N6851 or SMD equivalent. Try to have the very high input impedance of current source oamp.
