i think the state of the art is 0.6v and 0.3v references, all of these use internal divider from a 1.25v bandgap - note that minimum supply is about 1.4v for any of them to show this point.
another approach is to use current references - a ptat current plus a ctat current summed across a small resistor will give bandgap action on any resistor you put in: 1mV to ...
as for negative voltage reference, the IC wont care! use -5v supply as GND, use GND as +5v supply and you will get a -5+1.25v bandgap. divide down to get -150mV.
hope this helps!
