Jan 4, 2004 #1 mrcube_ns Advanced Member level 1 Joined Apr 10, 2002 Messages 452 Helped 48 Reputation 96 Reaction score 34 Trophy points 1,308 Location Europe Activity points 3,813 I use AEC programmer software with AT89S8252. I need to make intel8 HEX file for programming eeprom on mcu. Is there any program for making HEX after I wrote something like this: on address 0x234 put byte 0x12 and so on... So after that program make HEX? Tnx in advance. Mr.Cube
Jan 4, 2004 #2 glenjoy Banned Joined Jan 1, 2004 Messages 962 Helped 72 Reputation 146 Reaction score 20 Trophy points 1,298 Location Philippines Activity points 0 Can you eleborate further? you mean start the program at memeory address 0234h?
Jan 4, 2004 #3 F FOX Member level 4 Joined Jun 24, 2001 Messages 73 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,288 Activity points 319 See the software WinHex https://www.x-ways.net/winhex/allfeatures.html perhaps useful to you
Jan 5, 2004 #4 C crono Member level 3 Joined May 1, 2001 Messages 59 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 767 hi here you will find detail on hex format www.cse.unsw.edu.au/~pleb/data_sheets/Hexfrmt.pdf www.intel.com/design/zapcode/Intel_HEX_32_Format.doc if you mean binary to hex conversion here is an example of this utility **broken link removed** Try a search by "binhex" or "bintohex" or "bin2hex" in a search engine. If you have a software for a eprom programmer (or with winhex) you may write in binary in the dump area and than save the file .bin to convert in hex. Of course you can find also many hex to bin utilityes.
