Oct 27, 2011 #1 J Jeffer Jiang Newbie level 2 Joined Aug 30, 2003 Messages 2 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 13 these are PC parallel ports driver's header file and Lib, who have ? can share to me, thanks!
Oct 27, 2011 #2 H Hewitson Advanced Member level 4 Joined Oct 31, 2010 Messages 100 Helped 12 Reputation 24 Reaction score 12 Trophy points 1,298 Activity points 1,798 It's commercial software.. There is a couple of free alternatives you might like to try, UserPort and DoIO.
Oct 27, 2011 #3 S srizbf Advanced Member level 5 Joined Apr 3, 2010 Messages 1,992 Helped 417 Reputation 840 Reaction score 329 Trophy points 1,363 Activity points 10,985 are you going to use parport2k header and lib for an existing code or developing new applications using parport ?
Oct 28, 2011 #4 J Jeffer Jiang Newbie level 2 Joined Aug 30, 2003 Messages 2 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 13 yes,i need the header and lib to compile existing code , who could share these files? thanks!
Oct 29, 2011 #5 S srizbf Advanced Member level 5 Joined Apr 3, 2010 Messages 1,992 Helped 417 Reputation 840 Reaction score 329 Trophy points 1,363 Activity points 10,985 if you are not able to get the header and libs , you can use inout32 or giveio by writing a stub header to be compatible to your original header.
Oct 29, 2011 #6 bigdogguru Administrator Joined Mar 12, 2010 Messages 9,821 Helped 2,350 Reputation 4,694 Reaction score 2,272 Trophy points 1,413 Location Southwest, USA Activity points 62,383 As it was mention before the Parport software is a commercial API, licenses can be purchased from: If you would like a freely available alternative, I would recommend visiting the following: **broken link removed** ParallelPort.net BigDog
