Need information regarding Transient Analysis output
jdp721
Member level 2
Member level 2
Hi.
I have a particular circuit block (to be precise, a switched capacitor 2nd order integrator), say block-A, which when transient simulated in Virtuoso ADE gives stable desired outputs.
Now, in the same schematic, when I am placing another circuit block-B (a regenerative comparator), without even any connection between the two blocks A and B, the transient output of block-A is showing ringing/oscillations !
It seems so strange that without any interaction between A and B, the output of A is getting affected due to the mere presence of B in the sch! Can anyone please explain this phenomenon?
Is it something like the presence of B is causing the simulator to decipher the ringing in A, which went otherwise unseen?!?
Influence of supplies?
Sources that are common between the two blocks (when no other connection is there between blocks A and B) are a "vdc" and a "vpulse" source, and the "gnd" (all from analogLib of Cadence).
I do not think that this will lead to any interation....:|
