hi,
i have read sth about USB and microcontroller and i want to do some simple example in USB micro. and also designing deriver for USB by windriver(jungo).well i hope sbd will help me in finding more about USB driver and windriver first and then USB micro.
thanks.
this for windriver. https://www.jungo.com
it s more cheap and easy to use the driver that give the manufactor (cypress motorola..). You can transmit data.
build a driver only if you have a very special thing to do..
jqp 8O 8O
Which one uC you want to use? If FX2 from Cypress then you don't need expensive windriver. You can download sources of Control Panel for FX2 from Cypresses web site. After studing this code you shouldn't have any problems to use it in your application.
You can see www.cypress.com and use ez-usb fx2(CY7c68013) a usb2 controller.Jungo windriver7.0 will help you trough driver and firmware both. At first you must design an simple project and you must pay attention to desing it. It is very important.
