Need help writing a timing debugger script in magma
kirangu
Junior Member level 2
I am planning to write a timing debugger script, which should dump out a report which briefs out reasons for the failure of top 10 failing end points.
Reason1 : Can be higher Skew
Reason2 : cells which are low drive cells.
Reason3 : Xtalk
Reason4 : bad tran/cap due to Fanout
Reason5 : bad tran/cap due to long net
Please some one help me writing the script and please suggest.
