[SOLVED] need help with RF remote control from pic to pic using pic16f628a with mikroC code
choura
Member level 1
algeria
hi friends
PLZ help in the second part of this project ( received part) , it uses pic16f628a to receive characters and Lighting leds for every char,
with the attachment file U will get the mikroC code of the part one and general circuit in proteus
if can someone help me with second part to run the circuit correctly, i was trying to do it but i failed.
Q: can i remove the oscillator crystal for two pic's
waiting for reply
thank you before
  • remote control.rar
please friends really I need help for this project. I was trying many examples but nothing running correctly except the part one .
Should the second PIC receive data serially and depending upon the data received, light the LEDs? What data are you sending? What is the format of data?
Reactions: choura
    choura
I just send characters F, B, R, L, and S using UART mode.
thankyou for your reply sir
also i'm using pic16f628a in transmitter part and the same pic in the receiver part
there is no help here.
please really I need this circuit.
I need just help in second part of the circuit ( programming of pic16f628a) ; this circuit is remote control based on UART mode to send "F, B, R, L, and S" from pic16f628a to pic16f628a this is the ferst part programming which works correctly with transmitter part but I know it has some errors
transmitter code
void main() {
TRISA = 0xFF; //set all pin of port A as an input
PORTA = 0x00;
TRISB = 0x00; //set all pin of port B as an output
PORTB = 0x00;
CMCON = 0x07;
UART1_Init(9600); // initialize UART module
Delay_ms(100);
while (1) {
if (PORTA.F0 == 0) { //if push button is pressed
Delay_ms(20);
if(PORTA.F0 == 0) { //send forword signal
UART1_Write('F');
Delay_ms(500);
if (PORTA.F1 == 0) { //if push button is pressed
Delay_ms(20);
if(PORTA.F1 == 0) {
UART1_Write('B');
Delay_ms(500);
if (PORTA.F2 == 0) { //if push button is pressed
Delay_ms(20);
if(PORTA.F2 == 0) {
UART1_Write('R');
Delay_ms(500);
if (PORTA.F3 == 0) { //if push button is pressed
Delay_ms(20);
if(PORTA.F3 == 0) {
UART1_Write('L');
Delay_ms(500);
if (PORTA.F4 == 0) { //if push button is pressed
Delay_ms(20);
if(PORTA.F4 == 0) {
UART1_Write('S');
Delay_ms(500);
code of receiver part when I tried to do it with two characters
void main() {
unsigned int receiver;
PORTA = 0x00;
TRISA = 0x00;
PORTB = 0x00;
TRISB = 0xFF; //set all pin of port B as an output
CMCON = 0x07;
Delay_ms(100);
while (1) {
if (UART1_Data_Ready() == 1) { // if data is received
UART1_Read_Text(receiver, "F", 500); // reads text until 'F' is found
; portA.F0 = 1;
Delay_ms(1000);
portA.F0 = 0;
break;
UART1_Read_Text(receiver, "B", 500); // reads text until 'B' is found
; portA.F1 = 1;
Delay_ms(1000);
portA.F1 = 0;
Break;
It's still not clear what you are trying to do.
Are you saying it works with a direct connection between transmit pin and receive pin but not over the wireless link or that it doesn't work at all?
If it DOES work with direct connection but fails with a wireless link, please tell us if you are using an AM or FM link. Normally you have to do some signal conditioning, it isn't a simple as just sending a single byte and expecting it to arrive correctly.
Brian.
my problem with second part; my example program of receiver part doesn't work, that's right I'll use the RF modules 4333.92 MHz, if some one help me with program because I don't have enough experiences with programming language.
thanks friends for replying to me
Why dont you just get the code from the mikro web site?
This has been done there repeatedly.
Lets establish something first: If you directly connect the two ends with wires, does it work?
I'm trying to work out whether the problem is in the transmit code, receive code or in the 433MHz link. You can't just send data to a TX module and pick it up at the receiver without some extra code but before looking at that, it's important that a direct link works properly.
Brian.
