Need help with programming AVR ATMEGA32
ahmed_mahmoud
Junior Member level 1
Dear all,
it is my first time to program AVR, and i can't upload the hex file (which i used "AVR studio" to generate it) on the chip using "AVRprog". Although I have reviewed the connection between serial port and the chip pins multiple times, as stated in data sheet , each time i press build error appears "No supported board found!". In short, is there another way to send the hex file, for instance, by using hyper terminal?
Best regards
I made one which upload the program on the ATmega32 using serial port COM1; however, I can't send the file using the AVRprog because it can't recognize the board.
You said you AVRprog, the datasheet
http://www.atmel.com/atmel/acrobat/doc1021.pdf
says:
AvrProg can program all devices in the AT90S baseline series of microcontrollers.
As an additional feature it can also program several of Atmel’s AT89S series of microcontrollers.
I don't think you can program an ATMEGA32 with it.
You can try a simple solution like AVR Programmer
USBasp is a great programmer and it is the one I use but you need a programmer in order to make because you need to program the onboard mcu.
Alex
I used AVRJTAG for details please visit
https://www.avrportal.com/?page=jtag
Regards,
---------- Post added at 10:44 ---------- Previous post was at 10:42 ----------
This interface works well without any problems.
I really appreciate your replies. I would like to know if there is a circuit of one of those programmers I could implement instead of purchasing it, which is compatible with AVR studio.
