[PIC] Need help with NRF24l01
Scolioza
Member level 1
Member level 1
Hi all.
I have a homework and I realy need help. I want to setup a simple comunication between 2 NRF24l01. The problem is that i am not allowed to use any already written software such as libraries, so i started to work on a library. I used 2 PIC 16877a and two NRF modules. I was able to read and write any of NRF registers but i cant make them to communicate. I will attach my code here (written in ccs c) and i hope that more experienced users can help me.
here is the code for general setings and read and write functions
#include <24L01_TX.h>
#include <NRF24L01.h>
#define IRQ     PIN_B0
#define CSN     PIN_B1
#define CE      PIN_B2
#use    rs232(uart1)
#use    fast_io(B)
int8 buffer[5];
int8 flag=0;
#INT_EXT
void RB0_isr(){
    flag=1;
    clear_interrupt(int_ext);
//  PRINTS ON RS232 READ VALUES
void serial_out(int1 n_bytes, int8 to_print,int8 reg) {
      int8 i;
      if (n_bytes==1){
         for(i=0;i<5;i++){
         printf("valoarea %u este ",i);
         printf("%u",buffer[i]);
         putc(13);
         delay_ms(1000);
      else{
         printf("valoarea reg %u este",reg);
         printf("  %u",to_print);
         putc(13);
         delay_ms(1000);
//WRITE IN 1BYTE REGISTER
void write_reg_1_B (int8 adresa, int8 valoare){
   int8 write_add=W_REGISTER+adresa;
   output_low(CSN);
   delay_us(5);
   spi_write(write_add);
   int dummy=spi_read();
   spi_write(valoare);
   dummy=spi_read();
   output_high(CSN);
   delay_us(5);
 //WRITE IN 5 BYTES REGISTER
void write_reg_5_B(int8 adresa,int8 valoare0,int8 valoare1,int8 valoare2,int8 valoare3,int8 valoare4 ){
   int8 i;
   int8 dummy;
   int8 buff[5];
   for(i=0;i<5;i++){
     switch(i){
         case 0:buff[0]=valoare0;
         break;
         case 1:buff[1]=valoare1;
         break;
         case 2:buff[2]=valoare2;
         break;
         case 3:buff[3]=valoare3;
         break;
         case 4:buff[4]=valoare4;
         break;
   output_low(CSN);
   delay_us(5);
   dummy=spi_read();
   for(i=0;i<5;i++){
      spi_write(buff[i]);
      dummy=spi_read();
    output_high(CSN);
//READ 1 BYTE REGISTER
int8 read_reg_1_B(int8 reg, int1 print){
     int read_add =R_REGISTER+reg;
     int val;
     int dummy;
     output_low(CSN);
     delay_us(5);
     spi_write(read_add);
     dummy=spi_read();
     spi_write(NOP);
     val=spi_read();
     if(print==1){
        serial_out(0,val,reg);
     output_high(CSN);
     delay_us(5);
     return val;
//  READ 5 BYTES REGISTER
void read_reg_5_B(int8 reg,int1 print) {
     int8 read_add=R_REGISTER+reg;
     int8 dummy;
     int8 i;
     output_low(CSN);
     delay_us(5);
     dummy=spi_read();
     for(i=0;i<5;i++){
        spi_write(NOP);
        buffer[i]=spi_read();
    output_high(CSN);
    if(print==true){
        serial_out(1,0,0) ;
//RX SET MODE
void set_rx(){
   int8 CONFIG_VAL=read_reg_1_B(CONFIG,0);
    if(!bit_test(CONFIG_VAL,PRIM_RX)){
       bit_set(CONFIG_VAL,PRIM_RX);
       write_reg_1_B(CONFIG,CONFIG_VAL);
       output_high(CE);
//TX SET MODE
void set_tx(){
   if(bit_test(CONFIG_VAL,PRIM_RX)){
      bit_clear(CONFIG_VAL,PRIM_RX);
      output_low(CE);
//START TRANSCEIVER
  void power_up() {
   if(!bit_test(CONFIG_VAL,PWR_UP)){
      bit_set(CONFIG_VAL,PWR_UP);
//STOP TRANSCEIVER
void power_down() {
   if(bit_test(CONFIG_VAL,PWR_UP)){
      bit_clear(CONFIG_VAL,PWR_UP);
//CLEAR INT. ON STATUS REGISTER  RX_DR
void set_status_rx_dr(){
   int8 STATUS_VAL=read_reg_1_B(STATUS,1);
   if(bit_test(STATUS_VAL,RX_DR)){
     bit_set(STATUS_VAL,RX_DR);
     write_reg_1_B(STATUS,STATUS_VAL);
//READ STATE OF RX_DR
 int1 read_status_rx_dr(){
    int1 flag_rx_dr=0;
        flag_rx_dr=1;
    return flag_rx_dr;
//CLEAR INT. ON STATUS REGISTER TX_DS
void set_status_tx_ds(){
   if(bit_test(STATUS_VAL,TX_DS)){
     bit_set(STATUS_VAL,TX_DS);
//READ STATE OF TX_DS
 int1 read_status_tx_ds(){
    int1 flag_tx_ds=0;
        flag_tx_ds=1;
    return flag_tx_ds;
//CLEAR INT. ON STATUS REGISTER MAX_RT
void set_status_max_rt(){
   if(bit_test(STATUS_VAL,MAX_RT)){
     bit_set(STATUS_VAL,MAX_RT);
     //int8 dummy=read_reg_1_B(STATUS,1);
//READ STATE OF MAX_RT
int1 read_status_max_rt(){
    int1 flag_max_rt=0;
        flag_max_rt=1;
    return flag_max_rt;
//WRITE IN TX_PAYLOAD
void write_tx_payload(int8 valoare0,int8 valoare1, int8 valoare2, int8 valoare3, int8 valoare4){
 int8 i;
 int8 dummy;
 int8 buff[5];
 for(i=0;i<5;i++){
     switch(i){
         break;
         break;
         break;
         break;
         break;
 output_low(CSN);
 spi_write(FLUSH_TX);
 dummy =spi_read();
 output_high(CSN);
 delay_ms(1);
 output_low(CSN);
 spi_write(W_TX_PAYLOAD);
 dummy = spi_read();
 spi_write(buff[0]);
 dummy=spi_read();
  spi_write(buff[1]);
 dummy=spi_read();
  spi_write(buff[2]);
 dummy=spi_read();
  spi_write(buff[3]);
 dummy=spi_read();
  spi_write(buff[4]);
 dummy=spi_read();
 output_high(CSN);
 output_high(CE);
 delay_us(20);
 while(flag==0){printf("NO INT");putc(13);}
 output_low(CE);
//READ IN RX_PAYLOAD
void read_rx_payload(){
   int8 i;
   int8 dummy;
   output_low(CSN);
   output_low(CE);
   spi_write(R_RX_PAYLOAD);
   dummy=spi_read();
   for(i=0;i<5;i++){
       spi_write(NOP);
   output_low(CSN);
   spi_write(FLUSH_RX);
   dummy=spi_read();
   output_high(CSN);
   delay_ms(1);
   output_high(CE);
and here is the main for RX:
 void main(){
   SET_TRIS_B(0b00000001);
   SET_TRIS_D(0b00000000);
   output_d(0);
   output_b(0);
   output_high(CSN);
   setup_comparator(NC_NC_NC_NC);
   setup_adc(ADC_OFF);
   enable_interrupts(GLOBAL);
   enable_interrupts(INT_EXT);
   ext_int_edge(H_TO_L);
   clear_interrupt(INT_EXT);
   setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_XMIT_L_TO_H|SPI_CLK_DIV_4); //setare spi mod0 , 2MHZ
   setup_uart(9600); // baud rate UART
   delay_ms(2000);
   printf("start___________");
   putc(13);
   delay_ms(1000);
   int dummy;
   int8 i;
   power_up();  //pornire transciever
   set_rx();   // setare mod RX
   //CONFIGURARE REGISTRII 8 BITI
   //dummy=read_reg_1_B(STATUS,1);
   write_reg_1_B(EN_AA,0b00000001);// auto ACK enabled on pipe P0
   //dummy=read_reg_1_B(EN_AA,1);
   write_reg_1_B(EN_RXADDR,0b00000001);  // rx pipe 0 enabled
   //dummy=read_reg_1_B(EN_RXADDR,1);
   write_reg_1_B(SETUP_AW,0b00000011);// numele adresei este pe 5 bytes
   //dummy=read_reg_1_B(SETUP_AW,1);
   write_reg_1_B(SETUP_RETR,0b00001111); // daca nu exista ack informatia este retransmisa de max 15 ori
   write_reg_1_B(RF_CH,0b00000010);      // frecventa de operare este setata la 2.4 GHZ
   write_reg_1_B(RF_SETUP,0b00000111);   // 1Mbps, putere de transmisie max
   write_reg_5_B(RX_ADDR_P0,0XE7,0XE7,0XE7,0XE7,0XE7); // adresa la care se primesc pachete se ut. PIPE 0
   write_reg_5_B(TX_ADDR,0XE7,0XE7,0XE7,0XE7,0XE7);    // adresa de la care se transmit pachete
   write_reg_1_B(RX_PW_P0,0b00000101);                 // numarul de bytes in payload - 5 bytes
   while(TRUE)
     read_reg_1_B(CONFIG,1);
     if(flag){
     printf("am primit o intrerupere");
      int1 check_int = read_status_rx_dr();
      if(check_int){
          printf("RECEPTIE OK !!");
          read_rx_payload();
          set_status_rx_dr();
          flag=0;
          for(i=0;i<5;i++){
            output_d(buffer[i]);
            delay_ms(500);
and here is the main for TX
void main(){
   output_b(0);
   output_high(CSN);
   output_high(CE);
   setup_adc(ADC_OFF);
   power_up();
   delay_ms(2000);
   putc(13);
   delay_ms(1000);
   int dummy;
   set_tx();
   //write_reg_1_B(CONFIG,)
  // dummy=read_reg_1_B(EN_RXADDR,1);
   write_reg_5_B(RX_ADDR_P0,0XE7,0XE7,0XE7,0XE7,0XE7);// adresa la care se primesc pachete se ut. PIPE 0
   read_reg_1_B(RX_PW_P0,1);
    flag=0;
   while(TRUE)
     write_tx_payload(1,2,4,8,16);
     if(flag){
     int1 check_int = read_status_tx_ds();
     if(check_int){
          printf("TRANSMISIE OK !!");
          set_status_tx_ds();
          flag=0;
Any help or hint will be very valuable.
PS.
I already read lots of tutorials and I think that is a missunderstooding but i cant figure where.
Thanks in advance
