hi i am trying to implement a fir filter that is in the paper that i attached its link below with vhdl . the problem is i cant find out what is inside the block diagrams in Figure3 .from section 3 in the paper it seems that we should use a state machine but i have some questions .
1- what is s(i) in state 1?
2- what should we do in state 3-6
3- what is tree shift adder i searched a lot but i couldn't find anything about it
thanks https://ieeexplore.ieee.org/document/6568146/?reload=true
Showing a block diagram won't be considered as copyright violation, I think.
As far as I understand, the paper is referring to parallel processing and distributed arithmetic, in so far it sounds unlikely that the implementation uses sequential circuits like state machines.
thanks . i didn't attached the paper because some times ago one of managers of forum told me that i shouldn't do it and that i should only provide the IEEE link . i attached some pics of the paper .can you tell me what is in the block diagrams ?
that's not the block diagram i meant ! i attached the block diagram that i meant here and the ROM address table too please don't delete them .
and i should ask a question about it to make it more clear :
our input is 8 bits but ROM address is 4 bits how should i connect them ?
**broken link removed****broken link removed**
i figured out how to implement shift register stage and ROM stage. but I'm stock at the tree shift adder stage . I implemented it from a block diagram from some other paper(i attached it ) and i attached my implementation too.
i have the following problems : 1-n stocks in 1 value and never changes .2- d should be 16 bits and ip1 and ip2 should be 32 bits but the multiplexer is supposed to put inputs directly into output according to sel. i tried to solve it by getting 16 bits of the inputs. is this way correct ?
i altered my previous block diagrams to the one i attached and i got some output results that i don't know if its alright or not ! in the output waveform of my reference paper output stays zero for 7 rising edge of clock pulse and then it gets changed . for my design it changes after 2 . can anybody give me a hint ? am i doing right or not ? i checked every block on tree shift adder and the others blocks are fine but i don't have a clue what i should expect from the output.
