Hi everyone,
Let me start by saying that I'm new to CPLDs and that I'm working with the Lattice ispLEVER starter software. I started my project with their 5000MX chip in mind.
In my design I want to connect several design blocks (memory, LCD, ALU, ect) together with a bus. I thought I could use tri-state devices to prevent bus contention, but I can't find any in the symbol library to implement this. Also I can't put "Z" into the VHDL without error.
I was told that MUXs could be used instead of tri-state devices. How is this so? I understand how you could use a MUX to run the addressing of the blocks. But how can you use a MUX to effectively "isolate" and "not isolate" a block from the bus?
Thanks in advance
david119
