A light-bulb and a resistor is connected in a serie. The resistor is 100 Ohm. And the voltage over the bulb is described as U=I^2/(0.8*10^-3).
If i connect the serie to a 100 Volt DC source, how do i calculate the current and the resistance over the bulb?
Well Let us first analyze the situation. Your problem is illustrated in a picture given below.
It is always better to have a picture to solve the problems,you know.
Here is the representation...
Hope that this picture completely match with your problem.
Now let us start...........
We have applied a 100V dc across the series combination. Let us assume the voltage drop inside the resistor is V
R and voltage drop across the bulb is V
B.
So the total voltage will be V
DC=100V= V
R + V
B
But from Ohm's Law. V
R = I* R = I*100
also from your problem V
B =
There fore we will get an equation given below
I
2/(0.8*10
-3) + I* 100 = 100 V
Simplifying this, we get
I
2 + 0.08 I = 0.08 V
Solving this for I, we get
I = .2456571371 & I = - 0.3256571371
Here , it is not wise to assume a negative value for current.
so let us take
I = 0.24566 A
This is the current that flows through the series combination.........
Now your question
see, we got the current, but to find resistance we need the voltage drop across the Bulb.
so
V
B =
V
B = .24566
2/(0.8*10
-3) = 75.4360445 V
V
R = I*R = .24566*100=24.566V (no need, but just calculated for fun!)
now , By ohm's Law, V=I*R
therefore, R = V/I = 75.4360445/0.24566 = 307.075 ohms.... the resistance offered by the bulb.
thus, your final answers are
Current, I = 0.24566 A
Resistance, R=307.075 ohms
