TheDasDet
Newbie level 2
- Joined
- Apr 25, 2013
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,293
I'm designing a simple archery traffic light circuit with an auto and manual mode. I'm using Proteus to simulate and mplab to right the code (c code using the c18 compiler). The problem is when I'm simulating on Proteus the inputs RB0 and RB1 aren't doing the right thing (there low instead of high) which is messing up the function of the circuit. Has any body got any ideas on what I'm doing wrong cause I can't seem to figure it out.
Circuit:
Circuit:
* File Name : Triffic Light *
* Version : 0.0 *
* Description : Archery Traffic Light sytem with both manual and auto modes. *
* Author : Cameron Ross *
* Target : Archery Traffic Lights *
* Compiler : Microchip C18 V3.40 C Compiler *
* IDE : Microchip MPLAB IDE v8.87 *
* Programmer : PICKit2 or PICKit3 *
* Last Updated : 26 Mar 2013 *
#pragma config PLLDIV = 5
#pragma config USBDIV = 2
#pragma config FOSC = HSPLL_HS
#pragma config PBADEN = OFF
#pragma config CPUDIV = OSC1_PLL2
#pragma config WDT = OFF, LVP = OFF
#include "p18f4550.h"
#include "delays.h"
unsigned char LightState[3] = {0x01, 0x04, 0x02};
unsigned char LightStatePointer = 0;
unsigned char Pswitch;
unsigned long Timer1 = 0x240; //2 min
unsigned long Timer2 = 0x480; //4 min
unsigned long Timer3 = 0x030; //10 sec
unsigned long Timer4 = 0x060; //20 sec
unsigned long Timer5 = 0xF50; //30 sec
unsigned long TimeRemaining; //Sequence length
unsigned long TimeRemaining2; //start delay length
unsigned char test;
void main()
TRISD = 0x00;
TRISB = 0xFF;
INTCON2bits.RBPU = 0;
while(1)
PORTD = LightState[LightStatePointer];
while((PORTB == 0x38) || (PORTB == 0x3A) || (PORTB == 0x34) || (PORTB == 0x36) || (PORTB == 0x34) || (PORTB == 0x2E) || (PORTB == 0x3F) || (PORTB == 0x3C) ) //automatick sequence set
if((PORTB == 0x2E) || (PORTB == 0x2C) || (PORTB == 0x36) || (PORTB == 0x34))
if((PORTB == 0x34) || (PORTB == 0x2C))
TimeRemaining2 = Timer4; //set 20sec start delay
if((PORTB == 0x36) || (PORTB == 0x2E))
TimeRemaining2 = Timer3; //set 10sec start delay
if((PORTB == 0x2E) || (PORTB == 0x2C))
TimeRemaining = Timer1; //2 min sequence length set
if((PORTB == 0x36) || (PORTB == 0x2C))
TimeRemaining = Timer2; //4 min sequence length set
while(LightStatePointer < 2)
while(TimeRemaining2 > 0)
Delay10KTCYx(250);
TimeRemaining2 --; //start delay while loop
LightStatePointer = 1; //sets light to green at start of sequence
PORTD = LightState[LightStatePointer]; //set Port d to the value at lightStatePointer
while(TimeRemaining > 0)
Delay10KTCYx(250);
TimeRemaining--; //Sequence length while loop
if((PORTB == 0x3A) || (PORTB == 0x38))
TimeRemaining = 0; //force stop
if(TimeRemaining == Timer5)
PORTD = 0X02; //turns on amber at 30s to go
LightStatePointer++;
if(PORTB == 0x3B)
LightStatePointer = 0; //manualy set light to Red
if(PORTB == 0x2F)
LightStatePointer = 1; //manualy set light to Green
if(PORTB == 0x37)
LightStatePointer = 2; //manualy set light to Amber
