antonydublin
Newbie level 5
Hello guys need your help.
I have two three-phase generators – one with power about 20 kW, and other with bigger power (about 50 kW). But I always must use the bigger one because of phase (current) unbalancing near 40-50% (which I could not correct for some reasons). From my calculating, for all loads smaller generator is quite enough. So, what I need is a device for balancing three-phase system to reduce cost of fuel, etc.
Are there some complete systems from any manufacturers that will do the job? Anyway, all references and suggestions should be helpful.
Thanks.
Thanks.
