Dear brothers ,
I need little help , I have build a electric fence energizer , it runs by 12v 7.2ah battery , which I picked it from my computer ups , so I need that battery charger circuit from my 18v liner transformer , and I have a 12v 10w solar plate , can I charge my battery with my solar panels , is it possible , please give me those circuits
Regards
The aim is to prevent battery voltage from going over 13.8 volts or so. This simple zener and NPN regulator might be sufficient.
PV panel voltage varies according to how much current you draw from it. No-load maximum voltage could be 19V or more. Maximum current flows when charging a drained battery, around 11V.
When battery V rises to 13.5V or so it receives a trickle charge for the remainder of the charging session. You may need to adjust values so that it does not start 'gassing' (losing electrolyte). It depends on what behavior you observe.
This circuit lacks features such as hysteresis and taper charge. If you wish you can add these features with an op amp and more components.
Maybe first and very important is to check what type of battery chemistry your 12v 7.2ah battery is (Lead Acid, Li-Ion, etc.?), read a bit or a lot online about how that kind of battery must be charged, then search online for battery charger circuits, if you look for online shops, most will deliver (and "free" of delivery costs over a certain amount), so it doesn't matter if you live in central New York or in a remote village in Kashmir
A member here usually recommends "Battery University" website for learning about batteries and charging.
I think that a 12V battery needs to be able to be charged up to 13.4 or similar volts, so you'd need a boost converter to raise the solar panels output to about 14V for charging.
Maybe there are electronic circuit and component retailers in Hyderabad who deliver to your area, if Digikey or RS-Online, Mouser, etc. are not an option for you.
