Veeramani.T
Newbie level 1
- Joined
- Apr 19, 2014
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 20
dear friends,
i used pic18f4550 for sending sms through gsm900.
i got the at commands correctly in hyper terminal.
the problem is ......
manually i send the AT commands from hyperterminal to gsm900, the module is sending the sms to my mobile.
but, gsm module is connected to PIC MC , i could not get the sms.
and my hardware connections are correct ( checked it)
i dont know what is happening?
my code is ...
my code is ...
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 #include<xc.h> #include<usart.h> #pragma config PLLDIV = 4, CPUDIV = OSC1_PLL2, FOSC = HS, FCMEN = OFF, IESO = OFF, PWRT = OFF, BOR = ON, BORV = 3, WDT = OFF, WDTPS = 32768 #pragma config MCLRE = ON, LPT1OSC = OFF, PBADEN = ON, CCP2MX = ON, STVREN = ON, LVP = OFF, XINST = OFF, VREGEN = OFF, ICPRT = OFF, DEBUG = ON #pragma config CP0 = OFF, CP1 = OFF, CP2 = OFF, CP3 = OFF, CPB = OFF, CPD = OFF, WRT0 = OFF, WRT1 = OFF, WRT2 = OFF, WRT3 = OFF #pragma config WRTB = OFF, WRTC = OFF, WRTD = OFF, EBTR0 = OFF, EBTR1 = OFF, EBTR2 = OFF, EBTR3 = OFF, EBTRB = OFF void string(unsigned char *s); unsigned int i=0,j; unsigned char serial_data; #define FREQ 20000000 // Frequency = 20MHz #define baud 9600 #define spbrg_value (((FREQ/64)/baud)-1) void string(unsigned char *s) { while(*s!=0x0) { TXREG=*s; for (j=0;j<100;j++); while(PIR1bits.TXIF==0) { } PIR1bits.TXIF==0; s++; } } void tx_data(unsigned char data1) { TXREG=data1; while(PIR1bits.TXIF==0); PIR1bits.TXIF=0; } void d1(void) { for (j=0;j<60000;j++); for (j=0;j<60000;j++); for (j=0;j<60000;j++); for (j=0;j<60000;j++); for (j=0;j<60000;j++); for (j=0;j<60000;j++); for (j=0;j<60000;j++); for (j=0;j<60000;j++); for (j=0;j<60000;j++); for (j=0;j<60000;j++); for (j=0;j<60000;j++); for (j=0;j<60000;j++); for (j=0;j<60000;j++); for (j=0;j<60000;j++); } void main(void) { TXSTAbits.SYNC=0; BAUDCONbits.BRG16=0; TXSTAbits.BRGH=0; SPBRG=spbrg_value; RCSTAbits.SPEN=1; TXSTAbits.TXEN=1; RCSTAbits.CREN=1; while(1) { string("AT\r\n"); d1(); d1(); d1(); d1(); string("AT+CMGF=1\r\n"); d1(); d1(); d1(); d1(); string("AT+CMGS=\"+91xxxxxxxxxx\"\r\n"); d1(); d1(); d1(); d1(); string("This is my test msg"); d1(); d1(); d1(); d1(); tx_data(0x1A); d1(); d1(); d1(); d1(); } }
