need help regarding MOSFET.
niks
Full Member level 3
Full Member level 3
regardingmosfet
Hi
Im using BSP88. Vds = 2.4,Vgs=2.4.When there is low to high transition at the GATE, im getting sudden shoot of 1.5 V at source side. It'll be there for 10uS then it settles down. Why its behaving like this? And whats the solution?
O Vcc = 2.4
> 470K
--|<- BSP88
> 6.8K
Regards
~niks~
sutapanaki
US
Can you clarify a bit. It is not very obvious from your drawing how the gate is connected. Is it driven separately or it is connected to the drain - you say both drain and gate are at 2.4v? Do you also mean that Vcc can simply have a value somewhere in the range you specified or it is also changing - like a signal?
flatulent
Advanced Member level 6
Middle Earth
gate-source capacitance
This looks like the gate-soruce capacitance is putting part of the gate drive on the source. Try slowing down the gate drive rise and fall times to see if it goes away.
niks
Full Member level 3
Full Member level 3
Actually the input will be at 2.4 V when Gate will be enabled.
aaaaa
Junior Member level 1
It is the current that flows into the gate to charge the G-S capacitor. The current flows into the G, than capacitivly coupled to S, through your S resistor and back. You can calculate required Q from GS capacity of your MOSFET and voltage (2,4V in your case).
superluminal
Member level 4
Member level 4
Inside a quantum well
can you draw it with any schematic program ? & please tell us if these values are from simulation or from your testbench
jodokus
Member level 3
Member level 3
I agree with the others that this must be caused by the g-s capacitance. Try lowering your resistance values or add a resistor in series with the gate to minimize this phenomenon. I don't know the rest of your schematic but maybe you are better off with a bipolar transistor here.
