need help regarding a programmer for AT89C51
su sharma
Junior Member level 1
Hello everyone,i had been trying to make a burner for AT89C51 since last two weeks but wasn't successful,half of the times the circuit failed and the rest half there was a programming error. can someone please send me a precise circuit diagram and process to program it...hoping for some help as soon as possible...
thank you
Hello su sharma,
Go to thread : https://www.edaboard.com/threads/221592/..
But Do read the whole thread as there are some programmers for s series atmel chips only not for c series(89c51 need to be programmed using parallel programmer)
Also i prefer you to use 89sxx i.e s series microcontroller they can be programmed easly and their programmers are simple to made..
If you want to use 89c51 you can use proload as in attachment..
Good luck
  • proload-5-4.zip
thank you so much for your reply...but i would like to ask you that have you tried this by your self? i mean the circuit seems to be very complex..should i really work on it?
Hello
Yes i have tried this, infact the picture of programmer in proload attachment is of mine programmer.. so dont worry Just go on.. but i really suggest you to go for 89s51/52 instead 89c51/52 as they are outdated and requires comparatively complex programmer..
And do read all the posts in the thread(link in my previous posts)
:p
ok...thank you so much for the suggestion
Oh my pleasure :)
You even dont hv to write this just click the helped me tab in the posts..
That circuit will surely work, just give it a try!!!
Good luck
i am unable to get you tushki7 ,
can you pls attach the circuit diagram you are talking about
Hello hiten09,
Circuit diagram is in my previous posts above.. Look for proload-5-4.zip
or here is the attachment :
and here is schematics: 89sch.gif
  • proload-5-4.zip
thanks,
but here u2 shows the pre programmed firmware chip, can you pls explain from which file we have to preprogram it?
and what is 74hc573 is it buffer ic? in u4 i have to place my controller to which i wants to use but what about u5? what i have to place in u5?
thanks,
Firmware hex file is in attachment zip file..yes 74hc573 is buffer ic..
U5 is for 20 pin at89c2051/4051 microcontrollers.. If you want to make a programmer for only 89c51 then you can ignore u.
hello tushki7
can you provide me the circuit diagram for ir sensor??
hello tushki7
This is not the right place to ask that.. always start new thread for different things..
second thing: first always search what you are looking for in thread there might be some similar threads which can solve your problems..
Ok for what purpose do you need ir sensor??
can u provide me wid the layout for the above mentioned processor...please
i mean the layout for at89c51 processor which u have made
---------- Post added at 23:45 ---------- Previous post was at 23:42 ----------
i m sorry for that..i m new to this site or any such site...so i'll be aware next time that where to ask a question
---------- Post added at 23:48 ---------- Previous post was at 23:45 ----------
Oh Dont be sorry :)
Here is the site from where you will get all you need : **broken link removed**
Dont download that proload programmer given at the site (it is 4.1version) , use proload 5.4 which is in attachment file..
Or here is what you want :
  • 89seriespcb.pdf
oh thank you so very much.....wish you a very happy new year...
my pleasure.. :)
A very very Happy new Year :)
Oh i am sorry for saying that .. Please delete your last post..
