From https://www.bit-tech.net/article/51/ ... **broken link removed**
I would like to adapt this circuit as an LED dimmer (C1 will be 33nF so the PWM frequency is higher...), but instead of the thermsistor, I'd like to use a phototransistor (less light = brighter LEDs). However, I'm not exactly sure on how to do it since a phototransistor lets more current through under a greater amount of light. What would be the best way to make the effect the inverse of this?
I think you could get the desired effect if you exchange the positions of r1 and r2. You should mount the phototransistor at position r2 and use a fixed resistor as r1.
