I have designed a SPDT switch on ADS. The problem is when taking practical results the bandwidth comes out to be only 100 MHz. But in simulation it is 500 MHz. I am using a shunt Switch configuration and using equivalent models for PIN DIDOES.Design file is attached. Kindly comment for increasing bandwidth
There are so many errors in your design. Such as in Schematic, your substrate Er=2.33, but in layout, the substrate is 9.6. And there are so many capacitors don't link to GND. You should carefully read about handbooks.
Good luck.
