Need help on forward body biasing!!
jatan1
Newbie level 3
Newbie level 3
Hi fellow members!
i need help on the topic of forward body biasing.
I am currently using the 65nm process with a wp/wn ratio of 240/120 which is 2.
In regards to the body of the pmos and nmos, i normally tie them to VDD and GND respectively. However, coming upon the topic of forward body biasing i am quite confused as to how should i implement the technique? Could anyone help me out? Thanks! :)
My goal is to simulate my circuit in ultra low power which Vdd as low as 0.2V to 0.4V. Would appreciate any form of help.
I am not a fan of this. Yes, you can lower the "effective VT"
by about 0.6V/V. But you also are forward-biasing the
parasitic BJT base, and even if you don't "quite" get to
elevated DC drain current you are pushing further into
substrate noise amplification.
Now with that low a VDD, maybe you can't light it up
and don't care.
I would suggest using a replica feedback bias scheme
to servo body voltage to "what you want from the FET".
If it's zero VT(1uA) then you put a G=0, S=0, B=amp
output, D w/ 1uA load = amp feedback replica device
in a control loop and hope for chip-wide matching.
But if you don't need that last couple octaves of speed,
you could just design in subthreshold and take what
comes, at much less complexity / risk.
and don't care.
i realize in some circuits, simply apply a "0" to the pmos body and this provides FBB. Dont seem to understand why though.
