Need help on digital clock
mtmaidoki
Newbie level 1
Newbie level 1
I am a novice in programming and working on the design of a digital clock with calendar and temperature display. Though, I have soldered the project to working conditions, I am encountering some difficulties which I suspect to be from the source code.
The problem is such that if I power the device, it seems to hang without showing the time, calendar and temperature. But after pressing the RESET button on several times it showed the data without running the clock and the current temperature is displayed only after I press the INCR button.
Thus attached are the circuit diagram and source code, and I hope someone would help me out. Thanks in advance
  • digital_clock.zip
try this basic steps..
originally posted by: ckshivaram sir,
1. try to do reset two or three times after power on..
2. check if the pin 9 is tied to Vcc permanently.
3. crystal oscillates or not, by measuring the voltage at pin 18 and 19.
3. what is the power supply you are using
4. Check with other controllers if they behave the same way.. if yes then its hardware problem.
5. check the power supply and current rating...
6. check if it is getting programmed properly...
https://www.edaboard.com/threads/217758/#post924092
