[SOLVED] Need Help on designing 4x3 matrix ALPHABETICAL KEYPAD using 8051
MANO.5
i want to design a ALPHABETICAL KEYPAD for one of my project that need to store some name on eeprom.When i was searching on web i didn't get anything.The following code is just numerical keypad ,it count and display how many times the key is pressed.I try to alter this code for ALPHABETICAL KEYPAD but i can't.please somebody help to solve this issue.
numerical keypad 4x3
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
//LCD Module Connections
sbit rs = P2^0;
sbit rw = P2^1;
sbit en = P2^2;
  #define dataport P1        // Data port for LCD
//End LCD Module Connections
//Keypad Connections
sbit R1 = P3^0;
sbit R2 = P3^1;
sbit R3 = P3^2;
sbit R4 = P3^3;
sbit C1 = P3^4;
sbit C2 = P3^5;
sbit C3 = P3^6;
sbit C4 = P3^7;
//End Keypad Connections
     void Delay(unsigned char msdelay)
    unsigned int j;
    unsigned char i;
    for(i=0;i<msdelay;i++)
    for(j=0;j<1275;j++);
void lcd_command(unsigned char comm)   //LCD command funtion
    dataport=comm;
    en=1;
    rs=0;
    rw=0;
    Delay(1);
    en=0;
void lcd_data(unsigned char disp)  //LCD data function
    dataport=disp;
    en=1;
    rs=1;
    rw=0;
    Delay(1);
    en=0;
void lcd_ini()
    lcd_command(0x38);
    Delay(5);
    lcd_command(0x0F);
        lcd_command(0x0E);
    Delay(5);
    lcd_command(0x01);
    Delay(5);
lcd_string(unsigned char *disp)  //LCD string function
    char x;
    for(x=0;disp[x]!=0;x++)
        lcd_data(disp[x]);
char Read_Keypad()
  C1=1;
  C2=1;
  C3=1;
  C4=1;
  R1=0;
  R2=1;
  R3=1;
  R4=1;
  if(C1==0){Delay(100);while(C1==0);return('1');}
  if(C2==0){Delay(100);while(C2==0);return '2';}
  if(C3==0){Delay(100);while(C3==0);return '3';}
  if(C4==0){Delay(100);while(C4==0);return '4';}
  R1=1;
  R2=0;
  R3=1;
  R4=1;
  if(C1==0){Delay(100);while(C1==0);return '5';}
  if(C2==0){Delay(100);while(C2==0);return '6';}
  if(C3==0){Delay(100);while(C3==0);return '7';}
  if(C4==0){Delay(100);while(C4==0);return '8';}
  R1=1;
  R2=1;
  R3=0;
  R4=1;
  if(C1==0){Delay(100);while(C1==0);return '9';}
  if(C2==0){Delay(100);while(C2==0);return '0';}
  if(C3==0){Delay(100);while(C3==0);return '=';}
  if(C4==0){Delay(100);while(C4==0);return '-';}
  R1=1;
  R2=1;
  R3=1;
  R4=0;
  if(C1==0){Delay(100);while(C1==0);return 'C';}
  if(C4==0){Delay(100);while(C4==0);return '+';}
  return 0;
void main()
   int i=0;
  char c,p;
   lcd_ini();
  while(1)
     lcd_command(0x01);
     lcd_command(0x80);
       lcd_string("Key  :");
         lcd_command(0xc0);
        lcd_string("Times:");
    while(!(c = Read_Keypad()));
      p=c;
    while(p==c)
      i++;
       lcd_command(0x88);
     lcd_data(c);
     lcd_command(0xC8);
       lcd_data(i+48);
      Delay(100);
    i=0;
Very ambiguous.
I wonder if they are looking for a method of text entry by multiple presses of the same key as on mobile phones. Otherwise it has to be bigger than 4x3.
What problem you are facing?
Hai venkatesh,
thank you for your reply..what i am trying was after getting pressed key value i add one more function set_key(c,i) in set_key function c was key value and i was number of times key pressed .In set key function using switch case key value is displayed.
The modified program was
#include<reg52.h> //including sfr registers for ports of the controller
sbit rs = P2^0;
sbit rw = P2^1;
sbit en = P2^2;
sbit R1 = P3^0;
sbit R2 = P3^1;
sbit R3 = P3^2;
sbit R4 = P3^3;
sbit C1 = P3^4;
sbit C2 = P3^5;
sbit C3 = P3^6;
sbit C4 = P3^7;
	unsigned int j;
	unsigned char i;
	dataport=comm;
	en=1;
	rs=0;
	rw=0;
	Delay(1);
	en=0;
	dataport=disp;
	en=1;
	rs=1;
	rw=0;
	Delay(1);
	en=0;
void lcd_ini()
	lcd_command(0x38);
	Delay(5);
	lcd_command(0x0F);
        lcd_command(0x0E);
	Delay(5);
	lcd_command(0x01);
	Delay(5);
	char x;
		lcd_data(disp[x]);
 void set_key(c,i)
switch(c)
  case 1:
    switch(i)
     case 1:{
	 lcd_command(0x80);
       lcd_data('a');
       Delay(50);
       break; }
     case 2:{
	 lcd_command(0x80);
       lcd_data('b');
       Delay(50);
       break;       }
     case 3: {
	 lcd_command(0x80);
       lcd_data('c');
       Delay(50);
       break; }
char Read_Keypad()
  C1=1;
  C2=1;
  C3=1;
  C4=1;
  R1=0;
  R2=1;
  R3=1;
  R4=1;
  R1=1;
  R2=0;
  R3=1;
  R4=1;
  R1=1;
  R2=1;
  R3=0;
  R4=1;
  R1=1;
  R2=1;
  R3=1;
  R4=0;
  return 0;
void main()
   int i=0;
  char c,p;
   lcd_ini();
  while(1)
    /* lcd_command(0x01);
     lcd_command(0x80);
    	 lcd_command(0xc0);
        lcd_string("Times:");	   */
	  p=c;
    while(p==c)
      i++;
	  set_key(c,i);
       /*lcd_command(0x88);
     lcd_data(c);
     lcd_command(0xC8);
       lcd_data(i+48);
      Delay(100);	 */
	  if(i==4)
	  i=0;
    i=0;
The program compiled without any error .But when simulating in proteus it didn't give anything.
Its a very easy project don worry. clear your main and check whether your LCD works fine or not ?
After making your LCD work there is nothing in the keyboard side. now lot of mistakes in the code.
So try to display some "hi" in lcd without keypad.
Also post your proteus project and hex file when you come next time.
Hai venkadesh,
there is no problem with lcd.it works fine.
hex file
  :1001FF00E4FEEEC39F5011E4FDFC0DBD00010CBCED
:08020F0004F8BDFBF50E80EAC6
:0102170022C4
:100218008F90D2A2C2A0C2A17F011201FFC2A22266
:100228008F90D2A2D2A0C2A17F011201FFC2A22246
:1001DC007F381202187F051201FF7F0F1202187F61
:1001EC000E1202187F051201FF7F011202187F0503
:0301FC000201FFFE
:0601B5008B088A09890A8B
:1001BB00E4F50BAB08AA09A90AAF0BEF3395E08F57
:1001CB0082F583120188FF6007120228050B80E37A
:0101DB002201
:10014C00EE7038EF147034AE04AF05EC702DEF2464
:10015C00FE6010146016240270217F801202187F3A
:10016C006180107F801202187F6280077F801202EC
:0C017C00187F631202287F321201FF225C
:10000300D2B4D2B5D2B6D2B7C2B0D2B1D2B2D2B3D1
:1000130020B40B7F641201FF30B4FD7F312220B581
:100023000B7F641201FF30B5FD7F322220B60B7FB8
:10003300641201FF30B6FD7F332220B70B7F6412B9
:1000430001FF30B7FD7F3422D2B0C2B1D2B2D2B3F6
:1000530020B40B7F641201FF30B4FD7F352220B53D
:100063000B7F641201FF30B5FD7F362220B60B7F74
:10007300641201FF30B6FD7F372220B70B7F641275
:1000830001FF30B7FD7F3822D2B0D2B1C2B2D2B3B2
:1000930020B40B7F641201FF30B4FD7F392220B5F9
:1000A3000B7F641201FF30B5FD7F302220B60B7F3A
:1000B300641201FF30B6FD7F3D2220B70B7F64122F
:1000C30001FF30B7FD7F2D22D2B0D2B1D2B2C2B37D
:1000D30020B40B7F641201FF30B4FD7F432220B5AF
:1000E3000B7F641201FF30B5FD7F302220B60B7FFA
:1000F300641201FF30B6FD7F3D2220B70B7F6412EF
:0B01030001FF30B7FD7F2B227F0022A0
:10010E00E4FBFA1201DC120003A907E960F8890C7E
:10011E00E50C6970240BBB00010AE9FF3395E0FE84
:10012E00AD03AC0212014CEB64044A7002FAFB12EE
:0E013E000003A907EF70D980F6E4FAFB80C831
:03000000020238C1
:0C023800787FE4F6D8FD75810C02010E01
:10018800BB010CE58229F582E5833AF583E022502C
:1001980006E92582F8E622BBFE06E92582F8E22276
:0D01A800E58229F582E5833AF583E4932290
:00000001FF
i can't upload proteus design ,the ploader says it was invalid file...........
Try this code, compress and post the project files.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
sbit rs = P2^0;
sbit rw = P2^1;
sbit en = P2^2;
sbit R1 = P3^0;
sbit R2 = P3^1;
sbit R3 = P3^2;
sbit R4 = P3^3;
sbit C1 = P3^4;
sbit C2 = P3^5;
sbit C3 = P3^6;
sbit C4 = P3^7;
void Delay(unsigned char);
void lcd_command(unsigned char);   //LCD command funtion
void lcd_data(unsigned char);  //LCD data function
void lcd_ini(void);
void lcd_string(unsigned char *);    //LCD string function
void set_key(unsigned int,unsigned int,unsigned int);
char Read_Keypad(void);
void main()
   unsigned int c = 0, p = 0, pos = 0, i = 0;
   lcd_ini();
  while(1)
    p = c;
    if(p == c)
      set_key(c,i,pos);
      if(++i >= 3)
      i=0;
    else
    i = 0;
    pos++;
void set_key(unsigned int c,unsigned int i, unsigned int pos)
    lcd_command(0x80 + pos);
    lcd_data('a' + c*3 + i );
    Delay(50);
    unsigned int j;
    unsigned char i;
    dataport=comm;
    en=1;
    rs=0;
    rw=0;
    Delay(1);
    en=0;
    dataport=disp;
    en=1;
    rs=1;
    rw=0;
    Delay(1);
    en=0;
void lcd_ini()
    lcd_command(0x38);
    Delay(5);
    lcd_command(0x0F);
        lcd_command(0x0E);
    Delay(5);
    lcd_command(0x01);
    Delay(5);
void lcd_string(unsigned char *disp)     //LCD string function
    char x;
        lcd_data(disp[x]);
  C1 = 1;  C2 = 1;  C3 = 1;  C4 = 1;
  R1 = 0;  R2 = 0;  R3 = 0;  R4 = 0;
  if( C1 && C2 && C3 && C4 )
  return 0;
  R1=0;
  R2=1;
  R3=1;
  R4=1;
  if(C1==0){Delay(100);while(C1==0);return 1;}
  if(C2==0){Delay(100);while(C2==0);return 2;}
  if(C3==0){Delay(100);while(C3==0);return 3;}
  if(C4==0){Delay(100);while(C4==0);return 4;}
  R1=1;
  R2=0;
  R3=1;
  R4=1;
  if(C1==0){Delay(100);while(C1==0);return 5;}
  if(C2==0){Delay(100);while(C2==0);return 6;}
  if(C3==0){Delay(100);while(C3==0);return 7;}
  if(C4==0){Delay(100);while(C4==0);return 8;}
  R1=1;
  R2=1;
  R3=0;
  R4=1;
  if(C1==0){Delay(100);while(C1==0);return 9;}
  if(C2==0){Delay(100);while(C2==0);return 10;}
  if(C3==0){Delay(100);while(C3==0);return 11;}
  if(C4==0){Delay(100);while(C4==0);return 12;}
  R1=1;
  R2=1;
  R3=1;
  R4=0;
  if(C1==0){Delay(100);while(C1==0);return 13;}
  if(C2==0){Delay(100);while(C2==0);return 14;}
  if(C3==0){Delay(100);while(C3==0);return 15;}
  if(C4==0){Delay(100);while(C4==0);return 16;}
  return 0;
Reactions: MANO.5
    MANO.5
Hai Venkadesh,
Thank you so much.Your code is working.I modify the code by adding EEPROM and forward,backspace key .I upload the protes design,HEX code. back space key is not working properly. please help to solve this problem also....
  • key pad.zip
Hi
in while make these change
Remember you cant press the same key consecutively in old code for that you need a timing mechanism.
I added timer in following code
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
while(1)
    p = c;
    time = 5000000;
    while(!(c = Read_Keypad()) &&  time--);
    if (time == 0)
    pos++;
    if(p == c && c != 14)
     set_key(c,i,pos);
      if(++i >= 3)
      i=0;
    else if(c == 14)
    pos--;
    set_key(c,i,pos);
    i = 0;
    else
    i = 0;
    pos++;
declare time as unsigned long
you can change the value for going to next char
Small change
Code C - [expand]
else if(c == 14)
    set_key(c,i,pos);
    pos--;
    i = 0;
Small change
Code C - [expand]
else if(c == 14)
    set_key(c,i,pos);
    pos--;
    i = 0;
Hai Venkatesh,
Thank you for your help.it was working now.........................
  • key.zip
Hai venkatesh,
There is small problem can't type like 'baby'.need something time counter .If same key is pressed within 10 seconds and if not increase pos value .Please some help............
reduce the value of time variable in #9. post the hex file, i can also have a try.
Hai
reduce the time value [time=5000000]; to [time=2];But no change.This is the hex file
:0F04DA00D2A3E4FFD2A4C2A40FEFC3940A40F54B
:0104E90022F0
:09051600D2A3D2A4C2A3C2A42204
:09051F00C2A4C2A3D2A4D2A322FB
:1003EF00AB07AA06C2D71205167FA0120404AF02EC
:0503FF00120404AF032D
:10040400E4FEFDEEC313FE70027E80EE5F6004D254
:10041400D78002C2D792A3D2A4C2A40DBD08E4D24D
:07042400A3D2A4A2A3C2A40D
:01042B0022AE
:10045300E4FFD2A3FEC2D7EF25E0FFD2A4A2A3C23A
:10046300A430D7010F0EC3EE6480948840E7D2A373
:04047300D2A4C2A4A9
:010477002262
:0404B4008C1E8D1FEE
:1004B8001203EFAF1F12040412051F7F0D02049BE5
:1004C8001203EF1205167FA1120404120453120539
:0104D8001F04
:0104D9002200
:10000300E4F508F509F50AF50B74FFF50CF50DE4B5
:10001300F50EF50FF510F511751502F514F513F539
:10002300121204781204DA85080A85090B12016694
:10003300EF3395E0F5088F094F700D781274FF12B6
:1000430003D1EC4D4E4F70E5E50B65097004E50AED
:100053006508704DE509640E45086045E509640FC0
:100063004508603DD3E50D940FE50C9400E50D4084
:100073001024F0F511E50C34FFF510E51124C080D0
:10008300022480FF1204EA120288050FE50F7002B2
:10009300050EC39403E50E940050030201450201CB
:1000A30010E509640E45087030E50D150D70021555
:1000B3000CD3E50D940FE50C9400E50D401024F0EE
:1000C300F511E50C34FFF510E51124C080022480FE
:1000D300FF1204EA1202888034E509640F450870B0
:1000E30033050DE50D7002050CD3940FE50C940058
:1000F300E50D401024F0F511E50C34FFF510E51182
:1001030024C080022480FF1204EA120288E4F50E60
:10011300F50F802EE4F50EF50F050DE50D700205C4
:100123000CD3940FE50C9400E50D401024F0F51169
:10013300E50C34FFF510E51124C080022480FF1282
:1001430004EAE4FFFEFDFCAB15AA14A913A812C32D
:100153001203BE600302002A050DE50D7002050CB3
:0301630002002A6D
:0C028800AB0DAA0CAD0FAC0EAF09AE0818
:0C0294008E168F178C188D198A1A8B1B80
:1002A000E4F51CF51DD3E5179409E51694004017F5
:1002B000E517940DE5169400500D7C007D031203A4
:1002C000ACEF2412020358E517640D4516702BE5B8
:1002D0001945187007F51C751D398068E51964010A
:1002E00045187007F51C751D2E8059E519640245E7
:1002F000187051F51C751D2D804AE517640E4516C2
:1003000070028008E517640F45167007F51C751D0F
:10031000208031E51764104516702FE519451870D7
:1003200007F51C751D2D801CE51964014518700723
:10033000F51C751D3D800DE519640245187005F525
:100340001C751D23AD1DAC1C801FAE16AF177C00A5
:100350007D031203ACEF243EFFE43EFEE5192FF5CA
:100360001DE5183EF51CAD1DFCAF1BAE1A1204B402
:0F037000AF1BAE1A1204C81204FA7F0A02049BD4
:10049B00E4FEEEC39F5011E4FDFC0DBD00010CBC4E
:0804AB0004F8BDFBF50E80EA28
:0104B3002226
:1004EA008F90D2A2C2A0C2A17F0112049BC2A222F3
:1004FA008F90D2A2D2A0C2A17F0112049BC2A222D3
:100478007F381204EA7F0512049B7F0F1204EA7F7B
:100488000E1204EA7F0512049B7F011204EA7F051D
:0304980002049BC0
:06042C008B208A218922C9
:10043200E4F523AB20AA21A922AF23EF3395E08F65
:1004420082F58312037FFF60071204FA052380E31B
:010452002287
:10016600D2B4D2B5D2B6D2B7C2B0C2B1C2B2C2B39D
:1001760030B40C30B50930B60630B7037F0022C262
:10018600B0D2B1D2B2D2B320B40B7F0A12049B30E4
:10019600B4FD7F012220B50B7F0A12049B30B5FD0A
:1001A6007F022220B60B7F0A12049B30B6FD7F0326
:1001B6002220B70B7F0A12049B30B7FD7F0422D2A0
:1001C600B0C2B1D2B2D2B320B40B7F0A12049B30B4
:1001D600B4FD7F052220B50B7F0A12049B30B5FDC6
:1001E6007F062220B60B7F0A12049B30B6FD7F07DE
:1001F6002220B70B7F0A12049B30B7FD7F0822D25C
:10020600B0D2B1C2B2D2B320B40B7F0A12049B3073
:10021600B4FD7F092220B50B7F0A12049B30B5FD81
:100226007F0A2220B60B7F0A12049B30B6FD7F0B95
:100236002220B70B7F0A12049B30B7FD7F0C22D217
:10024600B0D2B1D2B2C2B320B40B7F0A12049B3033
:10025600B4FD7F0D2220B50B7F0A12049B30B5FD3D
:100266007F0E2220B60B7F0A12049B30B6FD7F0F4D
:100276002220B70B7F0A12049B30B7FD7F10227F26
:02028600002254
:0300000002050AEC
:0C050A00787FE4F6D8FD75812302000321
:10037F00BB010CE58229F582E5833AF583E0225033
:10038F0006E92582F8E622BBFE06E92582F8E2227D
:0D039F00E58229F582E5833AF583E4932297
:1003AC00EF8DF0A4A8F0CF8CF0A428CE8DF0A42E65
:0203BC00FE221F
:1003BE00EB9FF5F0EA9E42F0E99D42F0E89C45F095
:0103CE00220C
:1003CF007401FF3395E0FEFDFC080808E6CF2FF619
:1003DF0018E6CE3EF618E6CD3DF618E6CC3CF622F2
:00000001FF
Hi make change,
instead of this
Code C - [expand]
code this
Code C - [expand]
while( ( !(c = Read_Keypad()) ) &&  time--);
and now try editing the time value..
Hai,
No change in output.............
Hai.
this code is working
while(1)
   p = c;
   time=15000;
    //while(!(c = Read_Keypad()) &&  time--);
	if (time == 0)
	 pos++;
    if(p == c && c != 14 && c != 15)
	  	if(pos>15)
		j=pos-16;
		 lcd_command(0xC0+j);
		else
	 	lcd_command(0x80+pos);
        set_key(c,i,pos);
		  if(++i >= 3)
        i=0;
    else if(c == 14)
    pos--;
	if(pos>15)
		 j=pos-16;
		else
    set_key(c,i,pos);
    i = 0;
	else if(c == 15)
    pos++;
	if(pos>15)
		 j=pos-16;
		else
    set_key(c,i,pos);
    i = 0;
    else
    i = 0;
    pos++;
	if(pos>15)
		 j=pos-16;
		else
but if we need to type "baby" the output is "b a by". BECAUSE pos value is incremented 2 times ... In first at //if (time == 0)
pos++ and second is
 else
    i = 0;
    pos++;
	if(pos>15)
		 j=pos-16;
		else
No change in output. it will show like "b a b y" and if time=0 before pressing any other key it will show some random values.... This is the proteus design and hex file....
  • key.zip
