[AVR] need help on attiny 24
farzinkalali
Newbie level 3
Newbie level 3
hi
I am trying to write a program in bascom for attiny24 that after counting 200 pulses set the pina.2
would you please help me
my program is like this do you find any mistake on it?
it compiled successfully on bascom with no errors
but when I load it on proteous 7 for simulation it doesn't work and it seems that get stuck on loop and do not exit the loop even when the pulses reaches to 200
please help me
thank you
Code dot - [expand]
1  $regfile = "attiny24.dat "
2  $crystal = 8000000
3  config pina.2 = output
4  Config Timer0 = Counter , Edge = Rising
5  Start:
6  Tcnt0 = 0
7  Do
8  Loop Until Tcnt0 = 200
9  End
10  Set Pina.2
11 Wait 1
12 reset pina.2
13 End
thank you
I don't know BASCOM AVR programming. I don't have that Compiler. Where is your Timer Interrupt Routine ? Timerx and Global Interrupts have to be enabled and a counter has to be incremented in Timer ISR on every interrupt. When count reaches 200 you have to toggle an LED or do whatever you want.
