gatzrulz
Newbie level 5
Hi all,
im facing the same problem... When i change the controller to 89s52 and load the hex in controller it works fine.. But when i select 89c2051 and burn the hex into the controller its not working. In debugging also only port bits are enabling. Somewhere problem with header or selection and sure that there is no problem with the hardware because it works fine with 89s52. Can anyone help me out pls.
I have attached the circuit.
