need help in wideswing casocode
avlsi
Member level 3
send me a design example of High Swing Cascode with both PMOS and NMOS devices.
Thanks in advance
The trick is to bias the gates of the cascode devices at the right level.
In the diagram, delta V refers to the vdsat of M3, M4, M5, M6.
See image 1 below.
If we bias the gate of M6 at Vgate_6 = Vdd - Vt - 2 delta V. then the
max output voltage that will still keep our transistors in saturation is
vout_max = Vgate_6 + Vt = Vdd - 2 delta V.
This is for a pmos.
For nmos, it is the same idea. You just have to bias the gate of M7, and M8 at Vt + 2Vdsat_8.
Then Vout_min = Vgate_8 - Vt = 2 Vdsat.
See diagram4 below.
The entire lecture slides is here:
Bob Brodersen explains those slides here:
watch the Mon, 10/11 lecture.
https://webcast.berkeley.edu/courses/archive.php?seriesid=1906978189
good luck.
Thanks a lot eecs4ever. I found ur info very useful.
