need help in the coding
sagd
Mumbai
I am uploading my code.. help me plz...
  • code.doc
What are the problems you are facing?
---------- Post added at 00:43 ---------- Previous post was at 00:29 ----------
Are you using mikroc pro? At a quick glance , there are some problems in the display part.
hey I am using mikroc pro... I am not able to get my display part. can you help??
The problems are :-
Lcd_Out(1,1,txt1);
Will print
"Baseline is" starting from 1st line char position 1 to char position 11.(count that).
and the following line:-
LCD_Out(1,3,baseline);
I see what you want to do.
But do as follows:-
replace "temp" by "baseline" and change accordingly for no of digits.
Code C - [expand]
8
9
10
11
ones=temp%10;
temp=temp/10;
tens=temp%10;
temp=temp/10;
hundreds=temp%10;
thous=temp/10;
Lcd_Chr(1,3,thous+48);
Lcd_Chr(1,4,hundreds+48);
Lcd_Chr(1,5,'.');
Lcd_Chr(1,6,tens+48);
Lcd_Chr(1,7,ones+48);
Remember to print digits of "baseline" after 11th char position
:-D
For mikroc pro.
If you feel that I helped you , there is a "helped me" button
---------- Post added at 00:36 ---------- Previous post was at 00:33 ----------
NB - For character use single quote like 'a' or '.' etc
