NEED help in sending SMS via through AVR studio 4 using ATMEGA32
harmonybunny0770
Newbie level 1
Hi i am currently working on sending sms via through a microcontroller(ATMEGA32) i am using AVR studio 4 and i'm using the USART commands apparently i've done the initialization and everything but i do not know why the data is still not sending out (I do not know why the UDR register is always empty and if my program run in the for loop twice the UDRE register will be cleared) PLEASE HELP ME !
here is my code (in c programming)
#include <stdio.h>
//#include <iostream.h>
//#include <cstdlib>
#include <avr/io.h>
//#include <stdlib.h>
//#include <string.h>
#define USART_BAUDRATE 9600
#define F_CPU 1843200
#define UBRR 23
#define BAUDRATE (F_CPU/(8*(UBRR+1))) //9600
int i;
//char *COMMAND;
int main ()
//Initialising--------------------------------------------------------------------------
/* Set frame format:
URSEL= 1 Selects UCSRC instead of UBRRH
UMSEL=0 Asynchronous Operation
UPM0=0 and UPM1=0 Parity Bit Disabled
USBS=0 1stop bit
UCSZ0=1 and UCSZ1=1 8data bits*/
UCSRC = (1<<URSEL)|(0<<UMSEL)|(0<<UPM0)|(0<<UPM1)|(0<<USBS)|(1<<UCSZ0)|(1<<UCSZ1);
/* Set baud rate */
UCSRC=(0<<URSEL);//Select zero to select to write UBRRH register
 	UBRRH = (unsigned char)(BAUDRATE >> 8); // Load upper 8-bits of the baud rate value into the high byte of the UBRR register
   	UBRRL = (unsigned char) BAUDRATE; // Load lower 8-bits of the baud rate value into the low byte of the UBRR register
// Set speed 230.4 Kbps
UCSRA = (1<<U2X);
/* Enable receiver and transmitter */
UCSRB = (1<<TXEN); //(1<<RXEN)|
//FinishedInitialising---------------------------------------------------------------------
//Sending AT Commands-----------------------------------------------------------------------
for (i=0; i<=42; i++)
	char COMMAND[44] = "ATAT+CMGF=1AT+CMGS=+61425460247\rHI\r";
	UDR = COMMAND[i]; // Send out the byte value in the variable "ByteToSend"
//	while (!(UCSRA & (1 << UDRE))) {}; // Do nothing until UDR is ready for more data to be written to it
//return 0;
