need help in read rpm of the fan using external interrupt in a given program by arduino uno
mobinmk
Full Member level 2
Full Member level 2
Kollam (Quilon),kerala, India
need help in read rpm of fan using external interrupt in given program by arduino uno
Hi Frndz,
Am new bie here.
i wana to make VFD of 3 phase induction motor.
succesfully i generate 3 pwm pulses by DDS technique used in aurdino uno.
the program is given below
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
 * DDS-sinewave - 3phase
#include "avr/pgmspace.h"
#include "avr/io.h"
PROGMEM  prog_uchar sine256[] =
  127,130,133,136,139,143,146,149,152,155,158,161,164,167,170,173,176,178,181,184,187,190,192,195,198,200,203,205,208,210,
 212,215,217,219,221,223,225,227,229,231,233,234,236,238,239,240,242,243,244,245,247,248,249,249,250,251,252,252,253,
253,253,254,254,254,254,254,254,254,253,253,253,252,252,251,250,249,249,248,247,245,244,243,242,240,239,238,236,234,
233,231,229,227,225,223,221,219,217,215,212,210,208,205,203,200,198,195,192,190,187,184,181,178,176,173,170,167,164,
161,158,155,152,149,146,143,139,136,133,130,127,124,121,118,115,111,108,105,102,99,96,93,90,87,84,81,78,76,73,70,67,64,
62,59,56,54,51,49,46,44,42,39,37,35,33,31,29,27,25,23,21,20,18,16,15,14,12,11,10,9,7,6,5,5,4,3,2,2,1,1,1,0,0,0,0,0,0,0,1,1,1,2,
2,3,4,5,5,6,7,9,10,11,12,14,15,16,18,20,21,23,25,27,29,31,33,35,37,39,42,44,46,49,51,54,56,59,62,64,67,70,73,76,78,81,84,87,
90,93,96,99,102,105,108,111,115,118,121,124
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
#define PWM_OUT_1 11  // PWM output on pin 11
#define PWM_OUT_2 10  // PWM output on pin 10
#define PWM_OUT_3 9  // PWM output on pin 9
#define LED_PIN  13  // LED status on pin 13
#define TEST_PIN 7  // Scope trigger on pin 7
#define POTEN_IN 0  // Potentiometer on pin 0
#define OFFSET_1 85  // Offset for second-phase
#define OFFSET_2 170  // Offset for third-phase
      double dfreq;
      const double refclk = 31376.6;  // measured
      const uint64_t twoTo32 = pow(2, 32); // compute value at startup and use as constant
      // variables used inside interrupt service declared as voilatile
      volatile uint8_t icnt;   // var inside interrupt
      volatile uint8_t icnt1;   // var inside interrupt
      volatile uint8_t c4ms;   // counter incremented every 4ms
      volatile uint32_t phase_accum;  // pahse accumulator
      volatile uint32_t tword_m;  // dds tuning word m
   void setup()
     pinMode(LED_PIN, OUTPUT);
     // sets the digital pin as output
     Serial.begin(115200);   // connect to the serial port
     Serial.println("DDS Test");
      pinMode(TEST_PIN, OUTPUT);         // sets the digital pin as output
      pinMode(PWM_OUT_1, OUTPUT);       // PWM output / frequency output
      pinMode(PWM_OUT_2, OUTPUT);       // PWM output / frequency output
      pinMode(PWM_OUT_3, OUTPUT);       // PWM output / frequency output
     // Setup the timers
     setup_timer1();
     setup_timer2();
       // disable interrupts to avoid timing distortion
       cbi (TIMSK0, TOIE0);             // disable Timer0 !!! delay() is now not available
       sbi (TIMSK2, TOIE2);             // enable Timer2 Interrupt
    dfreq = 1000.0;                // initial output frequency = 1000.0 Hz
    tword_m = twoTo32 * dfreq / refclk;       // calulate DDS new tuning word
  void loop()
    if (c4ms > 250)                // timer / wait for a full second
      c4ms = 0;
      dfreq = analogRead(POTEN_IN);        // read Poti on analog pin 0 to adjust output frequency from 0..1023 Hz
      cbi (TIMSK2, TOIE2);            // disble Timer2 Interrupt
      Serial.print(dfreq);
      Serial.print("  ");
      Serial.println(tword_m);
   // timer1 setup
 // set prscaler to 1, PWM mode to phase correct PWM,  16000000/512 = 31.25kHz clock
    void setup_timer1(void)
      // Timer1 Clock Prescaler to : 1
      sbi (TCCR1B, CS10);
      cbi (TCCR1B, CS11);
      cbi (TCCR1B, CS12);
      // Timer0 PWM Mode set to Phase Correct PWM
      cbi (TCCR1A, COM1A0);           // clear Compare Match
      sbi (TCCR1A, COM1A1);
      cbi (TCCR1A, COM1B0);           // clear Compare Match
      sbi (TCCR1A, COM1B1);
      sbi (TCCR1A, WGM10);            // Mode 1  / Phase Correct PWM
      cbi (TCCR1A, WGM11);
      cbi (TCCR1B, WGM12);
      cbi (TCCR1B, WGM13);
    // timer2 setup
    void setup_timer2(void)
      // Timer2 Clock Prescaler to : 1
      sbi (TCCR2B, CS20);
      cbi (TCCR2B, CS21);
      cbi (TCCR2B, CS22);
  // Timer2 PWM Mode set to Phase Correct PWM
    cbi (TCCR2A, COM2A0);           // clear Compare Match
    sbi (TCCR2A, COM2A1);
    sbi (TCCR2A, WGM20);            // Mode 1  / Phase Correct PWM
    cbi (TCCR2A, WGM21);
    cbi (TCCR2B, WGM22);
// Timer2 Interrupt Service at 31.25kHz = 32us
// this is the timebase REFCLOCK for the DDS generator
// FOUT = (M (REFCLK)) / (2 exp 32)
// runtime : 8 microseconds ( inclusive push and pop)
ISR(TIMER2_OVF_vect)
  sbi(PORTD, TEST_PIN);           // Test / set PORTD,TEST_PIN high to observe timing with a oscope
  phase_accum += tword_m;          // soft DDS, phase accu with 32 bits
  icnt = phase_accum >> 24;          // use upper 8 bits for phase accu as frequency information
  OCR2A = pgm_read_byte_near(sine256 + icnt);  // read value fron ROM sine table and send to PWM DAC
  OCR1A = pgm_read_byte_near(sine256 + (uint8_t)(icnt + OFFSET_1));
  OCR1B = pgm_read_byte_near(sine256 + (uint8_t)(icnt + OFFSET_2));
  if (icnt1++ == 125)             // increment variable c4ms every 4 milliseconds
        c4ms++;
      icnt1 = 0;
  cbi(PORTD, TEST_PIN);           // reset PORTD,TEST_PIN
nw i wana to read rpm of motor using hall sensor connected to pin 2 or 3, external interrupt.
also i wana to display the rotor speed in lcd display
pls help me to add prgrm in above sketch
regards
mobin
Re: need help in read rpm of fan using external interrupt in given program by arduino
If your admisible error is shorter than a full revolution time, you need a polling (sampling) timer.
If the error could be greater than few RPMs, you could use an external interrupt to count the rotor revolution during a predefined time interval.
thnks sir,
this is my final program
#include "avr/io.h"
      double dfreq;
      volatile uint8_t iAtt;  // signal attenuation (percent): 0 .. 100
      volatile uint8_t iSine1; // sine table value (phase 1): 0 .. 255
      volatile uint8_t iSine2; // sine table value (phase 2): 0 .. 255
      volatile uint8_t iSine3; // sine table value (phase 3): 0 .. 255
   void setup()
     // Setup the timers
     setup_timer1();
     setup_timer2();
  void loop()
      c4ms = 0;
      iAtt = 50;
      Serial.print("  ");
   // timer1 setup
      sbi (TCCR1B, CS10);
      cbi (TCCR1B, CS11);
      cbi (TCCR1B, CS12);
    // timer2 setup
      sbi (TCCR2B, CS20);
      cbi (TCCR2B, CS21);
      cbi (TCCR2B, CS22);
  // Perform the attenuation:
  iSine1 = int(pgm_read_byte_near(sine256 + icnt));  // read value fron ROM sine table
  iSine1 = round(iSine1*iAtt/100); // get the attenuated sine value
  iSine2 = int(pgm_read_byte_near(sine256 + (uint8_t)(icnt + OFFSET_1)));
  iSine2 = round(iSine2*iAtt/100);
  iSine3 = int(pgm_read_byte_near(sine256 + (uint8_t)(icnt + OFFSET_2)));
  iSine3 = round(iSine3*iAtt/100);
// Now set the PWM DAC
  OCR2A = byte(iSine1);
  OCR1A = byte(iSine2);
  OCR1B = byte(iSine3);
        c4ms++;
      icnt1 = 0;
i wana to measure the rpm of 3 phase induction motor using hall sensor ,by external interrupt in arduino uno
pls check the program to measure rpm
2 programs there.
1 is read rpm
2nd is read rpm and avg
i wana to add these code in my final program
// read RPM
volatile int rpmcount = 0;//see **broken link removed**
int rpm = 0;
unsigned long lastmillis = 0;
void setup(){
 Serial.begin(9600);
 attachInterrupt(0, rpm_fan, FALLING);//interrupt cero (0) is on pin two(2).
void loop(){
 if (millis() - lastmillis == 1000){  /*Uptade every one second, this will be equal to reading frecuency (Hz).*/
 detachInterrupt(0);    //Disable interrupt when calculating
 rpm = rpmcount * 60;  /* Convert frecuency to RPM, note: this works for one interruption per full rotation. For two interrups per full rotation use rpmcount * 30.*/
 Serial.print("RPM =\t"); //print the word "RPM" and tab.
 Serial.print(rpm); // print the rpm value.
 Serial.print("\t Hz=\t"); //print the word "Hz".
 Serial.println(rpmcount); /*print revolutions per second or Hz. And print new line or enter.*/
 rpmcount = 0; // Restart the RPM counter
 lastmillis = millis(); // Uptade lasmillis
 attachInterrupt(0, rpm_fan, FALLING); //enable interrupt
void rpm_fan(){ /* this code will be executed every time the interrupt 0 (pin2) gets low.*/
  rpmcount++;
// Elimelec Lopez - April 25th 2013
Code v2 (Calculate Average)
Download RPM_V2.ino
// read RPM and calculate average every then readings.
const int numreadings = 10;
int readings[numreadings];
unsigned long average = 0;
int index = 0;
unsigned long total;
unsigned long rpm = 0;
void setup(){
 Serial.begin(9600);
void loop(){
 if (millis() - lastmillis >= 1000){  /*Uptade every one second, this will be equal to reading frecuency (Hz).*/
 total = 0;
 readings[index] = rpmcount * 60;  /* Convert frecuency to RPM, note: this works for one interruption per full rotation. For two interrups per full rotation use rpmcount * 30.*/
 for (int x=0; x<=9; x++){
   total = total + readings[x];
 average = total / numreadings;
 rpm = average;
 index++;
 if(index >= numreadings){
  index=0;
if (millis() > 11000){  // wait for RPMs average to get stable
 Serial.print(" RPM = ");
 Serial.println(rpm);
  rpmcount++;
The second block of code is enough (it calculates both last read and the average RPM). Use the last read value for error correction and the average one for displaying on LCD.
thnks sir,
i wana to implement pid controller .
how to designing the valuesof kp,ki,kd for different refernce speed??
Why do you want to implement a speed controller? Induction motors have only a small, well predictable torque proportional slip. And in case of a fan, there will be effectively no load variations.
Controller parameters can be either empirically determined (e.g. using Ziegler-Nichols method) or estimated based on a control process model.
    V
I don't know the Arduino library and if it can be easily used to tune a speed controller. Generally it's suggested to know the basic control process properties before attempting to autotune it.
