[General] Need help in MplabX and pic24f
Proteus Sample Designs have Explorer 16 Board which has PIC24FJ. Use it to simulate your Projects.
i trying with this code but he display mean error in fucnction
void lcd_delay() { mSecDelay(2); }  // if LCD does not work make this longer
XC16 has a delay function, e.g. use
#include <libpic30.h>
void __delay_ms(unsigned int time);
and i dont have this file .h
#include "hardware.h"
#include "lcd.h"
thanks in advance
remove them - they are used in the rest of my project
Reactions: ings
    ings
Plz Milan you talk about ISIS ? or another simulator because in ISIS i dnt find Explorer 16?
Horace i m adding this include but i have the ame error with LCD_Delay
replace the call to lcd_delay() with __delay_ms()
lcd_delay() is one of my own functions driven by a timer interrupt
Reactions: ings
    ings
but you have definned this function 2*
void __delay_ms() { mSecDelay(2);
so i m delete one of these finction but he display me a error in delay_ms
as __delay_ms() uses loops for the delay you need to specify the clock frequency
e.g. this compiles OK with XC8
    #include <xc.h>        /* XC8 General Include File */
#define _XTAL_FREQ 400000
int main(void)
            __delay_ms(100);
Reactions: ings
    ings
yes i have defined the fCY but the same error with delay_ms
delay_ms is defined twise
main.c: In function '__delay_ms':
main.c:38:1: error: number of arguments doesn't match prototype
i thos line
void __delay_ms() { mSecDelay(2); }
i delete
and when i delete
he displa me this error
main.c: In function 'lcdNibble':
main.c:50:9: warning: unused variable 'lcd'
main.c: In function 'main':
main.c:45:1: warning: control reaches end of non-void function
in my original code replace this function
with
#define _XTAL_FREQ 400000    // replace with your frequency
void lcd_delay() { __delay_ms(2); }  //
Reactions: ings
    ings
the error now is :
build/default/production/main.o(.text+0x6): In function `.LSM1':
: undefined reference to `___delay_ms'
make[2]: *** [dist/default/production/LCD_pic24f_hello.X.production.hex] Error 255
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
yes
but is it ot necssarry to addd the configuation of bits or it is not important?
yes
you need the configuration bits to set up the oscillator, watchdog times, etc
you can see the defualt settings under Window > PIC Memory Views > Configuration Bits and generate an output file from them to include in your code for modification
see
https://microchip.wikidot.com/mplabx:view-and-set-configuration-bits
https://singularengineer.com/programming-pic-18-using-xc8-mplab-x-configuration-bits-2/
Reactions: ings
    ings
i m adding this configuration of the bits but alo he dont workand aloso the poble with delay_ms
: undefined reference to `___delay_ms'build/default/production/main.o(.text+0x6): In function `.LSM1':
another question plz iff i want o test my programm with startt kit directly i dont need any programmer (icd2 or icd3), i can directly send my programm in pic24f starter kit and test my program in the kit or it is a abligation to hve icd3?
Why don't you zip and post the complete project files so that it can be tested.
in this file my project in mplabx and isis i hope that yo will find tis error
  • forum.rar
looked at header libpic30.h and the "16-Bit Language Tools Libraries Reference Manual” and rather than XTAL_FREQ (required for XC8) it requires FCY instruction frequency to be defined before including it
e.g.
#define FCY 400000
also in main() should
   LCD_Out(1,1,"LCD Test...");
be
    lcdString(1,1,"LCD Test...");
Reactions: ings
    ings
in this case we have this error :
main.c:38:6: error: expected identifier or '(' before '{' token
main.c:181:5: warning: pointer targets in passing argument 3 of 'lcdString' differ in signedness
main.c:115:6: note: expected 'unsigned char *' but argument is of type 'char *'
make[2]: *** [build/default/production/main.o] Error 255
nbproject/Makefile-default.mk:94: recipe for target 'build/default/production/main.o' failed
BUILD FAILED (exit value 2, total time: 460ms)
in thi 2 line
    lcdCmd(_LCD_CLEAR);
try this project - it builds Ok for me
  • forum1.zip
Reactions: ings
    ings
