weifeng
Junior Member level 1
hi,
can anyone help mi to modify this RTC program?
there is an error when i build it in MPLAB IDE. I am using C18 compiler.
the 3rd line in red is an error....
#define DS1307_SDA PIN_B1
#define DS1307_SCL PIN_B0
#use i2c(master, sda=DS1307_SDA, scl=DS1307_SCL)
// initial DS1307
void init_DS1307()
output_float(DS1307_SCL);
output_float(DS1307_SDA);
// write data one byte to
// DS1307
void write_DS1307(byte address, BYTE data)
short int status;
i2c_start();
i2c_write(0xd0);
i2c_write(address);
i2c_write(data);
i2c_stop();
i2c_start();
status=i2c_write(0xd0);
while(status==1)
i2c_start();
// read data one byte from DS1307
BYTE read_DS1307(byte address)
BYTE data;
i2c_start();
i2c_write(0xd0);
i2c_write(address);
i2c_start();
i2c_write(0xd1);
data=i2c_read(0);
i2c_stop();
return(data);
// initial DS1307
void init_DS1307()
// DS1307
short int status;
i2c_start();
i2c_write(0xd0);
i2c_write(address);
i2c_write(data);
i2c_stop();
i2c_start();
while(status==1)
i2c_start();
BYTE data;
i2c_start();
i2c_write(0xd0);
i2c_write(address);
i2c_start();
i2c_write(0xd1);
data=i2c_read(0);
i2c_stop();
return(data);
