[AVR] Need help in conversion of 8byte hex array to the decimal value
Maverick_391
Newbie level 3
Newbie level 3
Pune, India
Dear all,
I need your help into conversion of array of 8 byte hex to the decimal value.
As I done this for 4 byte but now stuck to do it for 8 byte!! Can anybody share a small program ृfor the same?
I am using 8 bit atmega AVR microcontroller and want to convert the incoming 8byte hex values to decimal and then send back it through serial.
Awaiting reply.
Thank you sir for your reply.
Is it possible to use long long unsigned int to hold a value? If yes then how I send that value over UART using sprintf?
Please reply.
You'll want to check the documentation of your compiler whether it supports 64 bit integer numbers or not. If not, you have to design your own conversion routines.
By the way, the original question title is completely misleading. Your asking about 64 bit integer, not hex array.
