Need Help for Ring buffer PIC18F2550 UART
embpic
Advanced Member level 3
india
I am using ring buffer for rx and tx in serial communication.but i am getting error. main data is tx correctly but after that garbage value get transmit.
// PIC18F2550 Configuration Bit Settings
#include <xc.h>
// CONFIG1L
#pragma config PLLDIV = 5       // PLL Prescaler Selection bits (Divide by 5 (20 MHz oscillator input))
#pragma config CPUDIV = OSC3_PLL4// System Clock Postscaler Selection bits ([Primary Oscillator Src: /3][96 MHz PLL Src: /4])
#pragma config USBDIV = 2       // USB Clock Selection bit (used in Full-Speed USB mode only; UCFG:FSEN = 1) (USB clock source comes from the 96 MHz PLL divided by 2)
// CONFIG1H
#pragma config FOSC = HSPLL_HS  // Oscillator Selection bits (HS oscillator, PLL enabled (HSPLL))
#pragma config FCMEN = ON       // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor enabled)
#pragma config IESO = OFF       // Internal/External Oscillator Switchover bit (Oscillator Switchover mode disabled)
// CONFIG2L
#pragma config PWRT = OFF       // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOR = ON         // Brown-out Reset Enable bits (Brown-out Reset enabled in hardware only (SBOREN is disabled))
#pragma config BORV = 3         // Brown-out Reset Voltage bits (Minimum setting)
#pragma config VREGEN = OFF     // USB Voltage Regulator Enable bit (USB voltage regulator disabled)
// CONFIG2H
#pragma config WDT = OFF        // Watchdog Timer Enable bit (WDT disabled (control is placed on the SWDTEN bit))
#pragma config WDTPS = 32768    // Watchdog Timer Postscale Select bits (1:32768)
// CONFIG3H
#pragma config CCP2MX = ON      // CCP2 MUX bit (CCP2 input/output is multiplexed with RC1)
#pragma config PBADEN = ON      // PORTB A/D Enable bit (PORTB<4:0> pins are configured as analog input channels on Reset)
#pragma config LPT1OSC = OFF    // Low-Power Timer 1 Oscillator Enable bit (Timer1 configured for higher power operation)
#pragma config MCLRE = ON       // MCLR Pin Enable bit (MCLR pin enabled; RE3 input pin disabled)
// CONFIG4L
#pragma config STVREN = OFF     // Stack Full/Underflow Reset Enable bit (Stack full/underflow will not cause Reset)
#pragma config LVP = OFF        // Single-Supply ICSP Enable bit (Single-Supply ICSP disabled)
#pragma config XINST = OFF      // Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
// CONFIG5L
#pragma config CP0 = OFF        // Code Protection bit (Block 0 (000800-001FFFh) is not code-protected)
#pragma config CP1 = OFF        // Code Protection bit (Block 1 (002000-003FFFh) is not code-protected)
#pragma config CP2 = OFF        // Code Protection bit (Block 2 (004000-005FFFh) is not code-protected)
#pragma config CP3 = OFF        // Code Protection bit (Block 3 (006000-007FFFh) is not code-protected)
// CONFIG5H
#pragma config CPB = OFF        // Boot Block Code Protection bit (Boot block (000000-0007FFh) is not code-protected)
#pragma config CPD = OFF        // Data EEPROM Code Protection bit (Data EEPROM is not code-protected)
// CONFIG6L
#pragma config WRT0 = OFF       // Write Protection bit (Block 0 (000800-001FFFh) is not write-protected)
#pragma config WRT1 = OFF       // Write Protection bit (Block 1 (002000-003FFFh) is not write-protected)
#pragma config WRT2 = OFF       // Write Protection bit (Block 2 (004000-005FFFh) is not write-protected)
#pragma config WRT3 = OFF       // Write Protection bit (Block 3 (006000-007FFFh) is not write-protected)
// CONFIG6H
#pragma config WRTC = OFF       // Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) are not write-protected)
#pragma config WRTB = OFF       // Boot Block Write Protection bit (Boot block (000000-0007FFh) is not write-protected)
#pragma config WRTD = OFF       // Data EEPROM Write Protection bit (Data EEPROM is not write-protected)
// CONFIG7L
#pragma config EBTR0 = OFF      // Table Read Protection bit (Block 0 (000800-001FFFh) is not protected from table reads executed in other blocks)
#pragma config EBTR1 = OFF      // Table Read Protection bit (Block 1 (002000-003FFFh) is not protected from table reads executed in other blocks)
#pragma config EBTR2 = OFF      // Table Read Protection bit (Block 2 (004000-005FFFh) is not protected from table reads executed in other blocks)
#pragma config EBTR3 = OFF      // Table Read Protection bit (Block 3 (006000-007FFFh) is not protected from table reads executed in other blocks)
// CONFIG7H
#pragma config EBTRB = OFF      // Boot Block Table Read Protection bit (Boot block (000000-0007FFh) is not protected from table reads executed in other blocks)
#include <string.h>
unsigned char *strr="1234567890ABCDEF";
unsigned char count=0;
unsigned char *array = "This is interrupt based transmission";
unsigned char dat[20];
volatile unsigned int head;
volatile unsigned int tail;
void send_uart(unsigned char dat);
void init_uart(void);
void tx_stn(unsigned char *str);
void delay(unsigned int del);
void delay_us(unsigned int del);
char read_from_buffer();
void store_in_buffer(unsigned char data);
unsigned char i=0;
void interrupt isr(void)
    if(RCIF)
	if(OERR) // If over run error, then reset the receiver
        	CREN = 0;
        	CREN = 1;
    else if(TXIF==1)
        i = read_from_buffer();
         if(i!='\0')            // if not null then only send
            TXREG = i;
       else
            i = 0;
void main()
    init_uart();
    i = 0;
    /********This one is not working************/
//    while(*strr!='\0')
//        store_in_buffer(*strr);
 //       *strr++;
       store_in_buffer('P');        // store data in buffer
       store_in_buffer('I');
       store_in_buffer('C');
       store_in_buffer('1');
       store_in_buffer('8');
    while(1);
void init_uart()
    TRISC6 = 1;
    TRISC7 = 1;
    PORTC = 0x00;
    RCSTA = 0x90;
    BAUDCON = 0x00;
    SPBRG = 77;                 //19200 baud rate
    TXSTA = 0x24;
    RCIE = 1;
    GIE = 1;
    PEIE = 1;
    TXIE = 1;
    while(!TXIF);
    TXREG = dat;
    delay_us(50);
    while(*str!='\0')
        send_uart(*str++);
        delay(1);
    unsigned int i,j;
    for(i=0;i<del;i++)
        for(j=0;j<120;j++);
    unsigned int i;
    for(i=0;i<del;i++);
  unsigned int next = (unsigned int)(head + 1) % 20;
  if (next != tail)
      dat[head] = data;
      head = next;
  // if the head isn't ahead of the tail, we don't have any characters
  if (head == tail) {
  return -1;        // quit with an error
  else {
    char data = dat[tail];
    tail = (unsigned int)(tail + 1) % 20;
    return data;
XC compiler
baud rate : 19200
hello,
  if(RCIF)
        	CREN = 0;
        	CREN = 1;
what do you do with RX interrupt ? Nothing ?
you don't treat the received char in RCREG ? put into a buffer ...
Several issues:
1. You need to clear TXIE when the buffer becomes empty and reenable it when new characters are placed into the buffer. Otherwise the TX-interrupt will trigger permanently.
2. Presently you are sending 0xff when read_from_buffer() returns -1.
3. Is this valid HiTech syntax to create a string constant together with a pointer to it? At least it's not generic C language.
Reactions: embpic
    embpic
@paulfjujo
I am not considering reception now but same concept i am using in reception also.
@FvM
yes sir i observed the error that is -1 that is 0xff coming continously.
sir i am new to this compiler so please correct it.
I have to correct my previous statement. The declaration of the pointer together with a string constant is correct according to the C specification. It's also mentioned in the HTC manual.
char *p = "abc";
defines p with type ‘‘pointer to char’’ and initializes it to point to an object with type ‘‘array of char’’ with length 4 whose elements are initialized with a character string literal.
The other point about stopping TX with empty buffer holds, however.
Thank you sir
but to disable the interrupt for transmitting is good??
this is my actual output.
Thank you sir but i have question that is there any efficient method better than this??
or this is best??
