Need Help for CS5460A ADC
jignesh doshi
Full Member level 2
Full Member level 2
hello friends,
I need some data for CS5460A ADC.
That is how to communicate this ADC with microcontroller.
in its datasheet i am not clear about communication part.
so please if you any one has data then please post it.
The device uses an industry standard SPI interface, it's usage is described in datasheet chapters 4. SERIAL PORT OVERVIEW and 5. REGISTER DESCRIPTIONS. There are also code examples at Codeforge.
Thanks FvM...
in chapter 4 they described over serial port overview but in that how IC works that they didn't describe.
how can i fatch data from IC that i can't understand from datasheet?
what i have to send sequence to IC for start the communication?
CS5460A isn't an ADC, it's a complete single phase energy measurement system, measuring voltage and current and calculating RMS, power and energy quantities.
Basic device operation, registers and how to access it through I2C protocol is described in the datasheet, in so far I don't know what your actual problem is. Besides Cyrrus support, you'll also find CS5460 related software application form other sources, e.g. ww1.microchip.com/downloads/en/AppNotes/00220a.pdf
