[SOLVED] Need help for choosing a linear voltage regulator
zeeekay
Junior Member level 3
Pakistan
Hi folks! I am currently designing a GSM based design needs 5V 650 mA current for charging interface . The design is size critical and we are using KTT version of LM317 for providing 5V-650 mA . The heat sinking is done by a solder masked pad on PCB. We need to power up design by 26V.
The problem we are facing is enormous heat generation. I understand that (Vi -Vo) is high enough and it is reasonable for heat to generate. However, I am unable to find another linear regulator with small form factor + SMD that we can use to meet my requirement.
Kindly help, if you have any info about a linear regulator which can stay "cool" and can meet our requirements.
In the described design form factor, the regulator's junction-to-ambient thermal restance will be almost independent of the specific regulator chip and rarely below 30 to 50 K/W. I leave it to your detail engineering work to calculate the resulting chip overtemperature at 26V input and 650 mA.
In a short, you simply must give up the idea of a linear regulator for the application.
This is a perennial problem, you can only dissipate the energy with a heatsink if you want to use a linear regulator. If you can tolerate a switching regulator you should look at a dc/dc convertor they can be quite efficient and needn't generate excessive heat. The size of a switching regulator will inevitably be bigger than a linear regulator but it would be smaller than a linear regulator including a heatsink.
Thanks everyone for help.. It seems a classical problem of its type.
I will try to find a high frequency switching regulator to minimize inductors/ capacitors size.
What is your suggestion ? Do you see any drawback of using a 1 MHz switching regulator. Can you specify any idcutor-less regulator that can suit my application.
Regards !
Regards !
Google for: 7805 switching replacement ..
Here is one example:
https://www.murata-ps.com/data/meters/dms-78xxsr.pdf
:wink:
IanP
A 1 MHz regulator should be fine as long as you don't have anything in the GSM receiver that's sensitive to that signal.
Such a regulator will require an inductor but it will be quite small because of the high switching frequency. Inductor size is inversely proportional to frequency for a given current output.
