Fix Phi(Φ=0), Theta (θ) is varied from -180 degree to +180 degree
Fix Phi(Φ= 90), Theta (θ) is Varied from -180 degree to +180 degree
Fix Theta(θ=90) , Phi (Φ) is varied from -180 degree to +180 degree
you will get all the planes now....
Is it the answer u wanted or u r searching for Copolar/Cross polar components?
Re: Need help finding xy, yz, xz- plane radiation pattern fo
hi,
In Phi (Φ)=0, called azimuth plane , E-phi is copolar component and E-theta is crosspolar component
In Phi(Φ)= 90, called Elevation plane, E-theta is crosspolar component and E-phi is copolar component
Hi
Thanks for the post.
Just want to confirm the order xy,yz and xz
XY-PLANE :Fix Phi(Φ=0), Theta (θ) is varied from -180 degree to +180 degree
YZ-PLANE: Fix Phi(Φ= 90), Theta (θ) is Varied from -180 degree to +180 degree
XZ-PLANE: Fix Theta(θ=90) , Phi (Φ) is varied from -180 degree to +180 degree
My order is right?
And if possible please let me know how to measure the IMPEDANCE BANDWIDTH if there are multiple
bands.
If there is single band, Impedance BW= (upper freq-lower freq)/center freq.
I came to know this through browsing. Is this right?
Please Reply me
Guest1234:: When u simulate a planar antenna or any structure in ADS layout, U can do a Farfield calculation to get the radiation pattern. It will be opened in a new window with 3D visualization, left to the pattern, u can find options with tabs placed below. U should be able to find the options for planes in radiation pattern and Gain of the structure, Etc..
