Need help finding a suitable voltage regulator IC.
rock94
Junior Member level 3
I'm planning to build a dual DC power supply unit over the weekend.The transformer I'm using is a 12-0-12 with a 3 amp output.There seem to be very few voltage regulators with a high output current.I do have the lm338k, but it doesn't seem to have a complementary negative voltage regulator.The only pair I've found online is the lm350/lm333.Unfortunately the lm333 is not available at any store though the lm350 is.Could anyone suggest me a pair with a current output >=3A or any other way around this.Also if I go ahead with the lm338 and build a 1.2-24v variable supply what are the drawbacks when compared to a Dual +12/0/-12 variable supply?Any thoughts or suggestions are welcome.
First You have to decide if You really need dual supply. There are not many applications which require that.
In college we used dual dc supplies to power op-amp circuits.I will be using it to test most of my DIY projects(Amplifiers at present). I would like to build a dual dc only if I find a good voltage regulator pair(just in case I need it later). Otherwise I'll go ahead with the lm338 design.
Have you looked for an LT1033? It is available from DigiKey and likely others.
Thanks,It seems to be quite old though.Unfortunately international shipping from the US is way too costly.:cry:
