CJD1
Newbie level 1
I am trying to design a amp trigger at 6 meters. I intent is to create a trigger circuit via the coax at the load back to the amp. Maybe having a choke in series with a cap and resistor which is tied to ground, then using a switch short the choke to ground by passing the cap and resistor. Then on the output stage of the amp sense the change and forward bias a switching transistor. The coax to the load would only be several feet long and the amp produces around 100 watts. :roll:
