Klaus, I already tried a Half Bridge and Full Bridge Rectifier, but the 3mhz N channel mosfets I bought, were not fast enough for some reason. All the I.C's that I've found for the 150khz range, top out at .1 Amperes Output for some reason - I don't want to use 2 of those IC's because of efficiency. Can anyone advise me on some mosfets or I'C's that may work here?
Brad, I am noob to electronic circuits. Can you post a picture of circuit? I thought you could only double voltage using A.C input using capacitors. The whole point of this project is so that I don't have to use anything that is plugged into a wall outlet socket.
Thanks
