[SOLVED] need help coding pic16f84a scanning of switches
ernestclydeachua
Junior Member level 1
hello i need help coding
i want to produce an out put like this
ive done some programming
and changed the ports it runs on simulation but wont run in the circuit it cause my LEDs to turn off and on when i energize a single switch
here the code
;RB0 controls RB7 and RA0
;RB0=0 then RB4 and RA0=0, else it will be 1 when RB0=1
;RB1 controls RB5 and RA1
;RB2 controls RB6 and RA2
;RB3 controls RB7 and RA3
	list      p=16F84A            ; list directive to define processor
	#include <p16F84A.inc>        ; processor specific variable definitions
	errorlevel -302, -207
	__config _CP_OFF &_XT_OSC & _PWRTE_ON & _WDT_OFF
cntr1	equ	h'21'
cntr2	equ	h'22'
bfr1	equ 	23h
	ORG     0x000             ; processor reset vector
  	goto    main              ; go to beginning of program
	ORG     0x004             ; interrupt vector location
	nop
	retfie                    ; return from interrupt
main:
	bsf	STATUS,RP0
	movlw	b'00000000'
	movwf	TRISA
	movlw	b'00001111'
	movwf	TRISB
	bcf	STATUS,RP0
newloop:
	movf PORTB,W
	movwf bfr1
	movf bfr1,W
	movwf PORTA
	rlf bfr1,F
	rlf bfr1,F
	rlf bfr1,F
	rlf bfr1,F
	movf bfr1,W
	movwf PORTB
	goto newloop
	end
Your code seems to work ok.
Is you circuit like mine below ?
You do not show pin 4 Mclre as pulled up, without that it will not run properly.
should i put capacitor connected to ground and to the resistor?
