monolothics
Junior Member level 3
Hi,,
I want to design a 4-bit High/Low Pass Phase Shifter with lumped element (L-C)
for all i know 4-bit phase shifter i will produce 16 difference phase shift that is : 0, 22.5, 45, 67.5, 90, 112.5, 135, ... , 337.5 (degree)
and also the 4-bit phase shifter consist of 4 phase bit = 180, 90, 45 and 22.5 (degree), and each phase bit will have 2 phase state
and usually the phase state is consist of phase 0 (degree) as phase reference usually at high pass branch and other value of phase in low pass branch
to create phase difference : ΔΦ = Φ high pass - Φ low pass ; the phase difference is represent the phase bit.
So the problems are : when i'm using 0 degree as my phase reference i couldn't find an appropriate value for my lumped elements but i can satisfy the value of 16 difference phase shift. But if i change the phase reference into any value i can get the value of the lumped elements but i couldn't get the value of 16 difference phase shift.
so anyone has an ideas how to solve this problem...
thank you
thank you
