I have seen on many commercial ups uses like this in the circuit. can anyone explain why this film capacitor & resistor (Red circled) is used in output? what is the advantage of using this? i want use like this in my home 1000w inverter output. so, what should be the value of capacitor & resistor and how to connect with output?
Dear aiubmehedi
Hi
It is simple . it used to remove High frequency noises . because a film capacitor has a lower ESL and ESR instead of electrolytic .
Best Wishes
Goldsmith
It is probably used to filter out any noise or spike in the UPS output.
You can try with capacitor values of 0.1uF, 0.22uF and 1uF. The value itself shouldn't be too critical. You can use the 3 values mentioned and try. Observe the output on an oscilloscope to see if you can detect any spikes or noise and adjust the value of the capacitance to remove/minimize the spike/noise.
Dear aiubmehedi
Hi
Best Wishes
Goldsmith
