need help about ad8055 opamp circuit
pure_lagi
Newbie level 2
ic ad8055
hello
I try to amplify RGB signal. I have ad8055 IC'es . need +2 gain. How can I do that with ad8055? is it right IC for this work? I looked at the Ic's Data sheet I think when I incrase the gain, bandwith will decrease. what is the exact maximum bandwith of RGB signal? Thank you so much for all suggestions and helpings
Regards
The AD8055 is 300MHz amplifier and RGB or composite vide bandwidth is below 10MHz ..
Here is an example of gain 2 amplifier .. see attached picture .. with -3dB bandwidth of ≈160MHz .. so don't worry about bandwidth ..
Regards,
IanP
    pure_lagi
Regards,
IanP
Thank you for the big helping.
Best Regards
